Oil leak on exhaust by flex pipe
Discussion in 'Volvo Forum' started by Johny41, Jan 11, 2018.
  1. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    What can can cause this oil leak? I blew turbo before Christmas, drove it home bob 100 miles with zero boost presure; last week i replaced turbo,air to air and DPF filter last, and i noticed this leak. Could this be caused by bad turbo installation, Engine,(piston rings?) Does Volvo D13 have some kind exhaust valve seal that could worn out and allow oil in exhaust, (I remember having this issue on my Detroit D60). O have 1.1 mil miles 2010
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Pull the side thats throwing oil to look at turbo seal to see if its leaking, Was a rebuilt turbo used if so find the papers to get a new not rebuilt one?
    Johny41 Thanks this.
  4. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I did the job at Volvo, it's a reman Holset Or something i asked for original, i've been told volvo doesn't supply original turbo anymore. Still 6000cad$, faulty part, what a garbage, I hope doesn't mess up my new Dpf again.
    url=https://flic.kr/p/222mzu2][​IMG][/url]20180103_103736 by johny392009, on Flickr
  5. baha
    4,137
    2,835
    Jul 25, 2013
    ga
    Its a good thing you found the bad turbo before it did cost you more?
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Doser leaking fuel?
  7. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    It's oil, I use synthetic Rottela T6, 5w40 looks like diesel .The truck starts easy normal, sounds ok, good mpg, no smoke ; I'll take it tomorrow back to Windsor, On Volvo. I hope to make it, I'm in Springfield,IL ,500 miles away and icy roads ahead.
    On my last truck,780/2008/D13 I replaced the turbo once at 1.1 mil miles,( with original volvo turbo, but now they don't have it :( , reman only ) sold it with 1,830,000 miles , never had this isues.
  8. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Did shaft break on last failure letting oil in exhaust? Or was just seizure on VGT sector shaft?
  9. Pedigreed Bulldog
    7,737
    14,421
    May 7, 2011
    When the turbo blew, it put oil into the exhaust. Unless they flushed that oil out, it'll be there until it leaks out, burns off, or blows out.
    spsauerland and Johny41 Thank this.
  10. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    The shaft was broken , but I I drove it 100 miles bob home with zero boost, was Saturday before Christmas, I count find a car to rent, shops closed.
    was a bad idea I cloged air to air and Dpf filter, replaced all.
  11. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I was thinking about this, i cleaned the oil leaking on the frame twice, and drove 2500 miles since was replaced, should be dry by now.
    Could this remain turbo be defective? Or I have a more sinister problem?! OMG I hope not :) :(
    I purchased this used lemon, im going to paint it yellow and take it in the desert like Jesse James, and post on YouTube, maybe make.more $$ than driving it ;
    baha Thanks this.
