Oil leak
Discussion in 'Freightliner Forum' started by Eightman, Mar 19, 2018.
  1. Eightman
    Eightman Bobtail Member
    Mar 19, 2018
    I have an oil leak on the right side of engine(DD15) against fire wall. IS this my main seal or what? Suggestions?
  3. JohnnyC
    JohnnyC Light Load Member
    173
    65
    Feb 17, 2009
    virginia beach, virginia
    I know this sounds crazy but check your valve cover for loose bolts.
    Intothesunset and Justrucking2 Thank this.
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    There are two seals, "Main" seals. One is located at the front of the motor behind the Damper, that big round chunk of metal at the front bottom of the motor which attaches to the crank shaft, the crankshaft makes your pistons go up and down. The seal is locate behind that damper in the block. That is your front seal.
    The rear seal is is at the other end of the crankshaft, where your transmission attaches to your motor. You need to drop the transmission to get to it.
    Odds are you have a leak at the valve cover, or you could have more serious issues and are leaking oil at the exhaust manifold.
    I would inspect with a flashlight, crawl up there and look, see if you can see where it is coming from. If you are unsure, power wash the area, run the truck and reinspect.
    About all I can say.
  5. Eightman
    Mar 19, 2018
    Thank you 4 your comments,area is extremely wet, going to power wash area and reassess -comments to follow
  6. Animosus
    Animosus Heavy Load Member
    710
    2,798
    Dec 7, 2015
    SE Wyoming
    I'm guessing it is a valve cover or cam frame.
    Hye Thanks this.
  7. 4vmach1
    4vmach1 Light Load Member
    184
    72
    Apr 3, 2013
    Los Angeles, CA
    Top or lower section of the engine? If the top then it can be from your cam frame or the rear cam frame plugs and your head gasket can leak from the passenger side rear corner.
  8. AModelCat
    155,507
    Rear main seal would make oil leak out into the bell housing (where the clutch is). If its leaking from above there, I'm 99% certain it wouldn't be the rear crank seal.
    Intothesunset Thanks this.
  9. Eightman
    Mar 19, 2018
    Thanks 4 the comments, put truck into freightliner shop. Oil is leaking from auxiliary turbine, $3800 to fix
  10. Justrucking2
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    Can you fix yourself?
  11. NightTruckerstreetlightx2
    NightTruckerstreetlightx2 Bobtail Member
    21
    4
    May 24, 2019
    Yeah, if its not the rear main or the bell housing where else could it be?
