I found oil just started leaking around the number two axle vent tube, what is the most likely cause.I felt the housing and they don't feel hotter than the rear one I can't imagine that the heat would cause that to happen
OIl leaking from Differential breather tube fitting
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by murat, Mar 4, 2020.
i would clean or replace that check valve
murat Thanks this. -
This morning with daylight and sleep I found the valve was loose where it screws into the housing.
truckdriver31 Thanks this. -
Tighten her up,if it still leaks probably plugged or needs replaced.
murat and truckdriver31 Thank this.
