Oil mixing with coolant in reservoir
Discussion in 'Volvo Forum' started by snupy5, Jan 30, 2013.
  1. snupy5
    snupy5 Bobtail Member
    I took my truck to shop because oil mixing with coolant in reservoir. Shop replace oil cooler and water pump. Within 24 hrs after getting truck out shop i notice truck using oil. I put 4 gallons of oil in truck within 3000 miles. It only started using oil after oil cooler and water pump been replace. Also engine came apart . Bearing came apart and hole in engine block. Anyone have suggestion to what couldve cause failure.
    Thank in advance
  3. TBT 5150
    TBT 5150 Bobtail Member
    25
    11
    Jan 24, 2013
    My mechanical exp would be 1. head gasket alowing oil to mix with the coolant. ( The head would have to be removed to confirm this ) Hope this helps.. TBT 5150
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,214
    Sep 23, 2007
    Statesville, NC
    Not really sure why they replaced a water pump. Oil/water mixed together tells me somewhere where the water jacket is seperated from the oil by a gasket, a gasket is either blown or you had a warped head.
    You can tell if you look at the Oil dipstick. You will see water since oil/water do not mix well.
  5. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Injector tube or injector cup leaking allowing it to mix
  6. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    i'm figureing out that there are TONS of place for oil and water to mix. not just the usual head gasket.
    and the transmission is another addition to those tons of things.
    Dave_in_AZ and Oldironfan Thank this.
  7. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    I would say you had coolant in your oil also and you spun a bearing. The level may have gone down due to it burning the water off after repairs.
    Was there any signs of water in oil? What engine is this?
  8. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    on all Volvo engines injector sleeves and heat exchanger (pass side of cyl block) are weak.
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
  10. Oscar_bis
    Oscar_bis Bobtail Member
    I also want to ask if anyone can help, I have been giving a truck to repair (TGX 26.460) with a fault of oil mixing with coolant. And as a mechanic, I have replaced a new oil cooler and start the the truck but the coolant keeps returning out from the reservoir and also with much oil coming out from the coolant radiator which freaks me up and don't know what else to do. Any help pls!
  11. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,541
    May 22, 2017
    Should have bought a D12 engine.
