Oil pan drain plug torque D12
Discussion in 'Volvo Forum' started by Damage, May 20, 2013.
  1. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    I am trying to find the torque spec on the D12 oil drain plug. I can not find it in my manuals. Its an 07 (the one that uses an 1 1/4" socket not the one with an allen head.) Thanks
  3. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    It's a plastic oil pan anyways so I just torque it enough where it really starts to tighten itself. Never had a problem.
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    I believe the last spec sheet I saw listed it as 35 ft lbs. Free advice and worth every penny :)
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Dude right the plug till you feel a click they have a torque bolt when you reach the right torque you're going to feel a click on you're ratchet that's enough.
  6. dorlia2
    dorlia2 Light Load Member
    149
    28
    Apr 20, 2012
    DOWNERS GROVE
  7. goranvolvo
    goranvolvo Bobtail Member
    19
    5
    Mar 2, 2013
    If you look on the oil pan you will se I think it is 45 NM
  8. Dell
    Dell Bobtail Member
    the torque setting for the drain plug is 60nm DO NOT OVER TIGHTEN you will crack the sump when undoing
  9. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
    Easy on those plugs. One time speedco busted both of my plugs
