Can you guys please let me know where you think I'm leaking from? You're looking at the bottom of a Cummins X15. Do you think it's the oil pan gasket or something more serious? TIA
Oil pan gasket leak?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JohnSmith69, Mar 26, 2025.
You could clean it all off and confirm the leak area to return. The small nature of the leak it may not come back right away.
My money is on the fuel pump gear pump oring between the gear pump and the high pressure pump. Fairly easy inexpensive repair.BoxCarKidd, D.Tibbitt, Rideandrepair and 1 other person Thank this. -
Thank you for the reply. How many hours is acceptable for labor? How much can I expect to pay?Goodysnap Thanks this.
Maybe 2-3 hour job max. 50 bucks in seals and gaskets.
Shop rates can vary greatly but 500 to 700 ish.blairandgretchen, Rideandrepair and JohnSmith69 Thank this.
