Oil Patch Trucking???
Discussion in 'Canadian Truckers Forum' started by thelongwalker, Nov 20, 2011.
  1. thelongwalker
    thelongwalker Light Load Member
    193
    38
    Aug 10, 2011
    Mission, British Columbia
    Can anyone describe to me exactly what you do when driving for Coil Tubing and Fracturing companies? What is a Flush By? Cement? Acid? Nitrogen?
    What do you do when you aren't driving? I can't seem to find any info on the jobs.
  3. itsneversafe
    itsneversafe Light Load Member
    267
    75
    Aug 16, 2011
    Victoria BC
    Fracturing is the process of pushing material into a well to open it up and flow better. Depending on the company you will haul flatdeck trailers with equipment, specialized tractors that haul the tanks for holding fluid and mixing. Acid is a pumping tandem truck or pump trailer that transports fluid as well you would haul fresh water for the cement mixers on site. Cement can either be self explanatory (cement mixer truck duh) or can mean hauling flat decks of dry cement in for an onside mixer. Any of these jobs will require onsite training by the company so I would just apply and let them sort out what they want you to do
  4. itsneversafe
    267
    75
    Aug 16, 2011
    Victoria BC
    And when not driving you sleep. Oil field exemption means your putting in 16 hour days by the time your clock runs out you will be hard pressed to get something to eat , shower and find a place to take a dump that isn't in a field at -30'with the wind blOwing
    thelongwalker Thanks this.
  5. itsneversafe
    267
    75
    Aug 16, 2011
    Victoria BC
    Btw if your applying try to have standard first aid, h2s alive beforehand as well if you can find a place in bc to do GODI training it will really help
  6. itsneversafe
    267
    75
    Aug 16, 2011
    Victoria BC
    But beware the patch can grow on ya
  7. bobbyt
    bobbyt Medium Load Member
    623
    108
    Jan 29, 2009
    Edmonton ab.
    in most cases, driving is only 10% of your job duties. when not driving you would be operating the equip on the truck. trican well servicing has alot of useful videos on the fracing, cementing jobs they offer. one job of a coil tube is to wash the sand out of the hole, where a soapy water-air combination is sent down the hole and flushes it back into a tank and the vac trucks haul it out for disposal. to find out about flushby's check out videos on you tube. basiclly it's a small truck mounted oil rig that services the oil wells.
  8. thelongwalker
    193
    38
    Aug 10, 2011
    I've just done the H2S course. I have TDG and WHIMIS as well. There is a job that interests me at Sanjel. It's bulk sand trucks. Super B-Trains I think. Know anything about that? Thanks for your informative posts by the way, I really appreciate you guys chiming in. :)
  9. cariboo_kid
    cariboo_kid Medium Load Member
    387
    104
    Oct 12, 2007
    Sask, Canada
    If I remember correctly you did the online H2S course, the companies usually require "H2S Alive" which is a one day course with a practical component. Available in Kamloops every 2 weeks from Valhalla.
  10. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Oil field truckin' ain't for everyone just like truckin' in general ain't for everyone. It'll seperate the boys from the men for sure because you won't spend but maybe 20-30% of you time driving, the rest will be on the ground doing manual labor.
  11. thelongwalker
    193
    38
    Aug 10, 2011
    I did the one day H2S Alive course here in Victoria with the practical (BA) component and CPR
