Oil Pressure light and High Coolant Temperature Light on with no codes
Discussion in 'Freightliner Forum' started by Smellfunny, Oct 18, 2012.
  1. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Had a 95 Freightliner FLD come into the shop with the buzzer going off and the Oil Pressure light and High Coolant Temperature Light on with no codes. Checked ground wires, tried some sensors, and tried a new EDM box. Finally traced it back to a bad fan solenoid. Thought I would post this because I had never ran across this before and finding out the fan solenoid was the fault of these lights coming on was surprising to me and thought it might help someone in the future.
    xsetra, Ale1466 and QUALITYTRUCK Thank this.
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    sucks about them older trucks.
    anything could be the problem but instead of one light or engine code. you get multiple lights.
  4. kubasj05
    kubasj05 Light Load Member
    148
    57
    Apr 18, 2013
    Do you have Detroit or Cummins engine ? I have a similar issuse minus oil pressure light, so just wondering if that could be same problem?
  5. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    This was a Detroit engine.
    kubasj05 Thanks this.
  6. kubasj05
    148
    57
    Apr 18, 2013
    Thats what I thought, I have Cummins M11 and found out that Detroit in 94+ substituted oil and coolant sensors wit EDM that is not present in Cummins engines, at least in 97 M11 that I have. None the less, thanks a bunch
  7. Ale1466
    Ale1466 Bobtail Member
    Mar 5, 2018
    Had the same issue with the same truck. Changed the fan solenoid and everything’s back to normal thanks for posting.
    Smellfunny Thanks this.
