Oil pressure loss when idle
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greggg, Jul 29, 2018.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    Hello,
    I have an issue since yesterday. 2008 international prostar Cummins isx.
    Whenever im at a red light or idling my oil pressure drops in between 13-19 depending on engine heat. It gives me a engine warning light. Then I keep driving pressure goes back up and engine warning light goes away.
    Just had an oil change and had them put Mobil 1 synthetic blend this time usually regular oil. I didn’t have them put Lucas oil stabilizer. Could that be the reason ?
  3. Greggg
    161
    35
    Jun 30, 2018
    Or can it be oil pump, bearings, other ? Take it to a mechanic and find out ? :) lol
  4. Heavyd
    Heavyd Road Train Member
    7,812
    6,264
    Feb 4, 2009
    Always verify with a mechanical gauge first. Then loss of oil pressure is usually a worn oil pump and/or pressure regulator. Bearing rolls do not increase oil pressure that significantly, maybe only a couple or few psi, but certainly not 15 psi. I would also recommend to pull the rocker cover and see if any cam bearing have walked out.
    Dave_in_AZ and AModelCat Thank this.
  5. AModelCat
    161,631
    ^^^ Always use a test gauge before you start throwing money at the problem. These gauges nowadays are electric/electronic. A poor connection or failing sensor can be enough to feed the gauge an incorrect reading.
    How recent was the oil change? Check your oil level and see if its over full. If you have fuel or coolant leaking into the oil it will dillute it and thin it out.
    Dave_in_AZ Thanks this.
  6. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,115
    Jul 12, 2017
    My first stop would be to pull the connector for the oil pressure sensor and look for oil leakage into the connector. Dead giveaway bad sensor. No point getting all excited over a 50 dollar sensor. Next step, get out the gauge an verify accuracy. Next most likely Is plugged oil filter. From there get out your wallet, never a good ending a rebuild could be in your future.
  7. Greggg
    161
    35
    Jun 30, 2018
    Wow thanks a lot guys ! Going to try all your suggestions and hope I don’t have to do a rebuild
  8. Greggg
    161
    35
    Jun 30, 2018
    Wonder what the price is on those. 10-15, Depending on the shop ? More ?
  9. Goodysnap
    3,748
    9,115
    Jul 12, 2017
    Quality In frame rebuild could run around twice that number depending on condition and parts needed. Remember I said quality, not cheapest backyard get ya by for a while.
  10. Greggg
    161
    35
    Jun 30, 2018
    ####. Yeah I like quality, cheap ain’t really cheap it keeps breaking. Thanks for all of the helpful info. If you could let me know if you have any good maintenance tips or any in general ?
  11. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Just a question; When the oil.was changed, they disdid put a lighter viscosity oil in than before?
