Oil pressure on Volvo D13 Engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by wallance, Feb 21, 2018.
  1. Great-Way
    Great-Way Light Load Member
    52
    61
    Mar 24, 2017
    BEAVERTON, MI
    just spoke with the shop via phone from my motel room. they are leaning towards a gear train failure. will keep you posted.
    Newto Trucking Thanks this.
  3. Great-Way
    52
    61
    Mar 24, 2017
    BEAVERTON, MI
    Had truck towed to M&K truck center in Byron MI. Today. Been reading on line about the D13 bull gear. Evidently it has a tendency to come loose and scrape beon bell housing which destroys the motor. If I had known about this potential I would have pulled transmission and secured the bull gear but with loctite for 2K.
  4. Great-Way
    52
    61
    Mar 24, 2017
    BEAVERTON, MI
    Update 8/12/2019
    Bull gear and idler gears all good.
    Had an apparent lube system failure.
    Two of the mains are obviously overheated. Tech said it looked like someone took a torch to them. Engine is seized up.
    At that point it it was determined that a remanufactured engine is best option.
    I found a replacement through JSJDiesel.com. Cost 14K and change but it's a 2014 with 240k miles..and matches my existing 2013 VNL engine serial and rev level. D13*0000000*H1*H
  5. Harjitmavi
    Harjitmavi Bobtail Member
    May 17, 2017
    Hello all..I have volvo 2015 with d13. Its motor died after it gave low oil pressure warning and halted on the highway. Got the reman engine installed from the volvo dealership. On the highway truck still shows 45psi oil pressure. It should be 60psi. Dealership told me to bring truck back but are not able to solve the issue. Any ideas?
  6. Chez809
    Chez809 Bobtail Member
    I’m having this exact issue with a 2014 Volvo change the oil pressure sensor and still wont go pass 30psi
  7. d13d
    d13d Bobtail Member
    Oct 17, 2021
    Hey, Did you ever figure this out? Currently researching possible solutions, all the shops have no clue. Thanks.
