Oil pressure problem!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Billy744, Jul 30, 2018.
  1. Billy744
    Billy744 Bobtail Member
    4
    Hello all, this is my first post on here. My oil pressure is moving back and forth at an idle. I've had no luck with diagnostics. Engines seems to run ok. However my yellow check engine light will come then my oil pressure goes back to normal but the power is cut down. Any advise would be great. Thanks
  3. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    Put a mechanical oil pressure gauge on it to varifv that that dash gauge is correct/ incorrect. Just a good place to start.
    SAR, stillwurkin and RET423 Thank this.
  4. Billy744
    4
    Thanks yes I did that and it was reading 36 and the gauge was staying there as well. I'm going to have the electrical checked now. Hopefully a wiring harness
  5. A5¢
    389
    544
    Oct 30, 2017
  6. Billy744
    4
    Just an update on this. Frieghtliner said there is a sending unit behind the drivers seat that sends data from the truck to the ecm. It's showing to be defective. I'll post weather it's a fix or not.
