oil pump/Detroit engine failure on 2013 Freightliner - ADVICE NEEDED!
Discussion in 'Freightliner Forum' started by daytonaoh, Mar 10, 2015.
  1. daytonaoh
    daytonaoh Bobtail Member
    47
    7
    Aug 1, 2013
    a low-mileage 2013 Freightliner was serviced by a major oil change franchise, with all oils and filters changed or topped off. The truck was deemed in tip-top condition. But within minutes of leaving the shop's location its Detroit engine blew up. The Freightliner dealer's technicians inspected the truck, and determined that the most likely cause of engine failure was oil pump's failure. At the same time, they also stated that the oil pump (and the engine) did not have any recalls and did not have any manufacturer's defects. Since the truck is fairly new, low-mileage, and did not have any problems before being serviced, yet after service had the catastrophic failure, it appears to be solely the fault of the oil change franchise.
    Who has had similar experience at any oil shop franchise and what are the suggestions in dealing with the situation?
    Also, who knows how could an oil change and other basic maintenance ruin the oil pump in a Detroit engine?
    Meanwhile, what can the engine codes reveal? As far as I understand they are useless, as they can't pin the blame on anyone - they just show if this or that failed.
    Thanks for all advice.
  3. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
    Did they dump a gallon of lucas in, it is so thick it can block the flow until mixed with oil.
  4. daytonaoh
    47
    7
    Aug 1, 2013
    The oil they used is described on the invoice as SH:RO15W40 BULK. Since the engine was not leaking and did not have any problems - except being due for basic service, oil change - why would they use Lucas? It is not denoted anywhere on the invoice, at least.
    Also, note that there were no error codes at the time of failure. And we know there were no leaks of oil after the failure, either.
  5. styenchko
    styenchko Bobtail Member
    19
    May 9, 2013
    Houston, TX
    Using Lucas on a newer Detroit will void the warranty. Right there in the manual, and most techs know that. But if it really was an oil pump failure the ecm would have shut the truck off before it siezed. Pretty sure that engine has an start-idle rpm lock that waits for the oil pressure to rise, so you can't even rev it on the pedal for a few seconds.
    Should be a code related to the oil pressure if really was the pump failing. But I would also look and see if those filters were unwrapped before installation.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    buddy can you say exactly what is happened ? you have a window on block, valve broke down? ........?
  7. daytonaoh
    47
    7
    Aug 1, 2013
    The dealer says that the oil pump led to the engine breakdown. Now the entire engine need replacement. I do not know if any valve broke down.
  8. mhyn
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    engine breakdown ? buddy I am asking what is happened exactly. bad rings? bad bushings? ...?
  9. mhyn
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    ok..you need to open the oil pan and inspect the bushings. if you run engine without oil first thing you will have bad worn crankshaft bushings. when oil pumps fails pressure goes down and 99% ecm shuts down engine. is it possible they added non engine oil in your truck ?
    daytonaoh Thanks this.
  10. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    Have them check ddec reports and see max engine speed. Did they change fuel filters? I am going to guess that they changed the fuel filters, did a dirty job, got an injector or two hung up, oversped the engine and spun a bearing
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    On a DD15 you cannot change both the oil and fuel filters at the same time or this will happen. You do one, start the engine, make sure everything is up to snuff. Shut 'er down, do the other, start it back up, good to go.
    Smellfunny, daytonaoh and BoxCarKidd Thank this.
