I've noticed since it has gotten colder out that the engine oil in my truck only runs around 160-170F loaded and 140-150F empty. Running bobtail it won't get much past 100F. Is this too low of a temp? The coolant temp stays right around 188-190F so I probably can't block much of the radiator or I'll run into heat issues with that.
oil temp too low
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gunner76, Dec 7, 2011.
Thats pretty much were my cat runs. Never had any trouble with it up here in the great frozen corn patch.
gunner76 Thanks this. -
I put a belly tarp on mine it keeps the oil within 20 degrees or so of the coolant.
Getting below 0 my oil temp gauge wouldn't even regster anytime just stayed bottomed out. At -15 to -30 it would use a LOT of oil w/o the belly tarp. -
both mine are the same bxs in pete and 3406e 550 in star,dont think its an issue
What engine do you have ?
My ACERT has the oil running a good 20 deg hotter than my coolant. I believe oil has it's own thermostat. -
I don't think you can have too low oil temp. if so you would have a sensor shut down ,as you do with too high oil temp.
The engine is made to run with the oil temperature at least at the coolant temperature. not below.
When I worked at a trucking company, we use to put on belly tarps from the front bumper to the mid point of the transmission. Secured to the bumper, and both frame rails. A modern engine uses the oil for coolant and the coolant to cool the oil, Get a tarp. -
You must be as old as I am! -
My oil temp on my 3406B would drop when running with a side wind blowing on the oil temp sensor side. If the oil pressure is not higher than normal you may be getting a false temp reading. If my coolant temp and oil pressure are normal I would not use a belly tarp.
