old fire hose
Discussion in 'Flatbed Trucking Forum' started by ford06, Mar 8, 2018.
  1. ford06
    ford06 Bobtail Member
    39
    13
    Mar 8, 2017
    does anyone use old fire hose for edge protection for your chains and straps does it work better than the plastic ones is it easier to store away
    jamespmack Thanks this.
  3. REO6205
    REO6205 Road Train Member
    13,172
    60,487
    Feb 15, 2014
    California.
    Check your local fire department for hose. The volunteer outfits usually have quite a bit. Give 'em a few bucks for it, they'll really appreciate it.
    We cut it into one foot lengths and then cut down one side along the edge.
    They make great edge protectors. They're tough enough to use with chains and limber enough to put under straps. We stow them in a five gallon bucket in the trailer gear box.
  4. MACK E-6
    48,287
    221,093
    Fire hose is pretty tough. It beats what I did, which was using pieces of carpet.
  5. hagarcobra
    hagarcobra Medium Load Member
    334
    747
    May 24, 2013
    Pieces of fire hose works great. I have pieces that I have a used for close to 10 years and they're still in good shape
  6. mtoo
    mtoo Road Train Member
    1,929
    4,433
    Jan 15, 2011
    Retired on bended knee
    I used old flaps "for tube type tires mounted on split rims". Cut them about 12 inches long. Can't wear them out, I have some that are 35 years old.
  7. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    If you can get it do it. I used old carpet remnants and anything else I could scrounge up. Use whatever works best that protects the customers product and your straps.
  8. jamespmack
    214,674
    Its also great to wrap pto lines with, protects rubbing. Now a warning! As a past Fireman Do not ever handle used fire hose without gloves. There can be small pieces of glass embedded in it from dragging it around accident scenes. Does not end well.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,827
    Sep 10, 2010
    Flint, MI
    Around here, I see fire hose on Craigslist at least weekly if not more often. Check there too.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I went to a store that specializes in hoses. Bought enough to add protection on my pipe stakes and have extra to cut into edge protectors.
  11. jamespmack
    214,674
    Most FD will give you the stuff, they test them every year. If they dont pass, or gets damaged its OOS. No use to them. Juat go ask them.
    MACK E-6 Thanks this.
