Omnitracs XRS will not change to “drive” from “on duty”
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Semidumper, Mar 25, 2021.
  1. Semidumper
    Semidumper Bobtail Member
    Nov 8, 2019
    23
    Thanks Received:
    4
    When I am moving the app says “in motion” but my duty status stays on ON DUTY instead of DRIVE ? I checked ecm and it’s getting power even replaced the relay and still same thing any suggestions
    randomly stopped switching
  2. Dieselboss
    Dieselboss Technology Contributor
    Feb 19, 2009
    1,648
    Thanks Received:
    1,365
    DieselBoss.com
    The mechanism that forces the change from "on-duty" to "drive" is the speedometer. The ECM reports the current speedometer reading to the ELD and when it goes over 5 MPH, the status flips to drive. When the vehicle stops a 5-minute timer begins. If the vehicle has not gone back over 5 MPH in 5 minutes then the XRS will automatically flip the status from "drive" to "on-duty."
    When I have seen this problem in the past on a truck that WAS ALREADY WWORKING CORRECTLY and then "randomly stopped switching" it was one of 4 things:
    1) The truck ECM or speedometer is no longer reporting the truck speed. You can verify this by signing into the XS admin site and looking at the historical track of the truck on the map. Are the speeds shown on every point up to right now? Also, a mechanic can hook up a scanner and check the speedo signals. Are there and XRS errors or malfunction messages in the hardware report section?
    2) The XRS relay. You said you have replaced that.
    3) The XRS cable. Cables sometimes do go bad or the pin in the socket that carries the speedometer signal has failed.
    4) The configuration (on the Omnitracs side) has changed. This could be a setting that accidentally got changed, or purposely changed during a software update. You should work with your account rep, or the hotline (800-541-5490) to have someone go over all of the truck configuration settings to ensure that it is not this.)
