on duty not driving after 14
Discussion in 'Trucking Industry Regulations' started by airforcetoo, Jul 6, 2012.
  1. airforcetoo
    airforcetoo Heavy Load Member
    892
    216
    Oct 4, 2011
    Up in the air
    It's legal to be on line 4 ”On Duty Not Driving” after your 14 is up - true or false
  3. scuba9278
    scuba9278 Bobtail Member
    28
    12
    Jun 24, 2012
    Butler, pennsylvania
    Stay on line 4 on duty not driving as long as you like lol :biggrin_25520: just remember you need to be on line 1 not on duty or line 2 in sleeper to reset
    airforcetoo Thanks this.
  4. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    Yes, you can be on line 4 after 14 or even 70 hours, you just can't drive.
  5. airforcetoo
    892
    216
    Oct 4, 2011
    Up in the air
    I thought 70 was the on duty max
  6. Sabine in Mo
    Sabine in Mo Medium Load Member
    602
    410
    May 11, 2006
    Fredericktown, MO
    70 is the max for driving, not for non critical work such as load, unload etc.
  7. TRUCK3R M1KE
    TRUCK3R M1KE Light Load Member
    168
    157
    Jun 27, 2012
    Spokane
    You can be on line 4 for 2 weeks straight (provided you don't need sleep, food, bathroom, etc). As long as you get your 34 Reset, you'll be good to go.
    Think of it like this....
    You only accrue logbook violations on Line 3.
    -Driving past your 70 in 8
    -Driving past your 11 or 14
    -Driving without proper 10-hour break (always, always, ALWAYS log your 10 as straight sleeper or straight off-duty, regardless of how you mix the two. This insures that you always have at least 8 on one of them no matter what).
    -Driving while being logged on a different status (counts as "Not Current")
    -Driving under disqualification, without CDL, without registration/insurance, etc.
    -Not being current on status (obviously you were driving to get pulled in/over and checked, as no one is going to wake you up to see if your logbook shows you as being in the sleeper).
    There are no violations specifically for Line 1, 2, & 4. It all has to do with whether you did what you needed to do to be legally operating the vehicle.
  8. Autocar
    3,167
    2,358
    Apr 28, 2012
    Actually, you could go from line 1 to line 2, back to line one, every fifteen minutes, for 10 hours and satisfy the 10 hour break rule. It would look screwy and raise some eyebrows, but it is 100% legal. Very seldom do I show 10 straight hours in the sleeper. It's normally 1 to 2 hours on line 1, generally 6 hours in the sleeper on line 2 and the rest of my 10 off, back on line 1. I have never been questioned on that, nor even raised an eyebrow.
  9. TRUCK3R M1KE
    168
    157
    Jun 27, 2012
    Spokane
    Incorrect.
    Sleeper Berth Provision - HOS Regulation valid until 7/1/2013
    -Drivers using the sleeper berth provision must take at least 8 consecutive hours in the sleeper berth, plus a separate 2 consecutive hours either in the sleeper berth, off duty, or any combination of the two.
    http://www.fmcsa.dot.gov/rules-regulations/topics/hos/index.htm
    *is why I just show it all on one line, and that's what I teach others.
    ibdbird Thanks this.
  10. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
    Dude wasn't referencing the split sleeper. He (that's an assumption Autocar could be a dudette) is just stating that for a 10 hour break you can change from 1 to 2 to 1 to 2 all willy nilly like and it wont matter as long as it's 10 consecutive hours without an interruption of line 3 or 4.
    LaBubba and DrtyDiesel Thank this.
  11. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    My e logs reset after 4 hours off duty and 6 off in sleeper. It must be okay since their e logs, the computer knows!!!!!!
    All kidding aside I usually log sleeper berth for all 10. I've had yo split log to make appt times. 8 hours in the sleeper, drive to shipper and spend 2 hours in the sleeper and boom, hours reset.
    Ethan
