On Duty vs. Off Duty while loading tankers
Discussion in 'Experienced Truckers' Advice' started by Silverbeard, Apr 19, 2024.
  1. Silverbeard
    Silverbeard Light Load Member
    61
    87
    Aug 2, 2017
    Houston TX
    I was recently told by a dispatcher to go off duty when loading at a shipper that sometimes takes 5-6 hours to load. The theory is that this somehow preserves available time once I'm loaded, but this is not correct. Nothing stops the 14 hour clock once it starts. So trying to preserve time during a single shift is not possible. Makes zero difference whether I stay on duty or go off duty....the 14 still ticks away. However, if I am made aware that the loading time might take 8-10 hours or more it might make sense to go off duty that entire time so I have a new clock when loaded, but I better be allowed to sleep that entire time which is unlikely to happen anyway.
    The only benefit to going off duty is to get the time back when you run into recap territory against your 70 hour clock. But being off duty thinking you are preserving your shift clock is not possible. Why does my dispatcher not understand this issue better? Am I missing something??
    Lav-25 and tscottme Thank this.
  3. LOTSO
    LOTSO Heavy Load Member
    885
    2,140
    Mar 28, 2023
    Well to me that 70 is just as important to preserve as the 14. You can stop the 14 hr. clock by going to Sleeper Birth status for at least 2 hrs. Now, drivers can, "make a point" and stay on duty as that might be the "legal" thing to do, but don't complain when the paycheck is small because your always out of hours.
  4. Brandt
    Brandt Road Train Member
    4,632
    6,368
    Sep 17, 2012
    Maybe they are confusing it with sleeper berth. Plus your not really off duty unless you are free leave or go do something you want to like go to the movies or play golf.
    silverspur Thanks this.
  5. TripleSix
    133,533
    You say ‘5-6 hours’ as if it’s common. Apparently, it must be rare for you to burn through your 70. My thoughts would be, after 5 or 6 hours of waiting, to be able to pound out 11 hours straight after recovering a full 10. You can’t do that if you’ve been fiddle farting around waiting on duty.
    If I sit 6, I will be taking 10, and without fail be able to run 11 and pound that ground. Can’t be done waiting on duty.
  6. tscottme
    tscottme Road Train Member
    Any time periods longer than 2 hours can freeze your 14 hour clock IF YOU SPEND IT IN SLEEPER, no place else. You can spend 2, 3, 4 or more in sleeper and then later you just need 10 minus what you last spent in sleeper (2,3,4, whatever) to satisfy the 10 hours you would normally take off-duty/sleeper. It's called the split sleeper berth rule. Sleeper is a type of off-duty, but only Sleeper Berth counts, not off-duty. It complicates your HOS using split-sleeper and it is very easy to have an egregious HOS violation if you screw up trying to use split sleeper.
    Gearjammin' Penguin Thanks this.
  7. Grumppy
    3,236
    11,428
    Dec 11, 2010
    West Monroe, La
    Tell dispatch if they don't like you burning up your time waiting, give the customer a call & take it up with them. You've got no control over load/unload time. Tell them either get with the customer on their load/unload time or suck it up. It aint your call. But, if they want you to make it your call, you can, but they probably won't like the outcome.
    RockinChair, mjd4277, MACK E-6 and 2 others Thank this.
  8. JC1971
    JC1971 Road Train Member
    2,684
    9,821
    Jul 29, 2013
    Southwestern U.S.
    No, it isn't 10 minus 4. It has to be a minimum of 7 hours in the sleeper to complete a split break. And two hours or more off-duty will stop your clock. Whether you can be off-duty at the dock is another issue which is why it's probably better to be in the sleeper to avoid any problems.
    Tb0n3, skallagrime, tscottme and 2 others Thank this.
  9. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
  10. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Unless rules have changed recently.
    You're required to be on duty when at shipper and receiver. Which obviously eats hours.
    I don't know the exact wording in the rule. And maybe with the new split sleeper. There might be a way to circumvent the rule. Saving hours.
    I'm local so I'm not up to date on the latest hos. I don't have to worry about them.
    mitrucker Thanks this.
  11. RockinChair
    RockinChair Road Train Member
    5,401
    14,543
    Feb 19, 2012
    Lubbock, TX & thereabouts
    5-6 hourd to load a tanker? Who takes that long, and what product?
