Onboard Scales Question ...
Discussion in 'Experienced Truckers' Advice' started by STexan, Jan 18, 2017.
  1. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    We have Air Weigh in-cab scales (digital with calibration menu) for tractor [we also have either gauges or digital for trailers]. Have any of you ever verified issues that might be related to altitude? I can't find any detail an altitude compensation for these devices but a web search seems to indicate they are supposed to have this feature but I'm unsure how it might supposed to work.
    I happened to notice while running across Wyoming I-80 my tractor readout was showing about 900-1000 lbs heavier with same fuel load (34,900) then it did in Vermont. So, to be safe, I scaled on a Cat scale at Wamsutter, and my real current weight was the same as my Air Weigh weight in Vermont, but it indicated 34,960 on the Wyoming scale when the Cat scale showed 33,900). I had just recalibrated this system a week or so ago in Dallas after loading, en-route to Albany. Loaded in Vermont and all seemed good. And was verified with Wyoming scale ticket.
    Anyone verified altitude issues or temperature issues that were significant with bag pressure systems? (the temperature was maybe 20 degrees colder in Wyoming than in Vermont)
  3. Blackshack46
    Blackshack46 Road Train Member
    I somehow cant believe altitude would change the readout. It may be an anomaly. I base this off a trucks air tanks. 120psi in your tanks is still 120psi. Now if you could measure the volume, it may change with high altitude thin air, compared to sea level air with high humidty. Still, youll only have 120-150 psi in reserve.
    I think you need a couple more runs to compare your findings.
    Duurtipoker Thanks this.
  4. Accidental Trucker
    Accidental Trucker Road Train Member
    3,407
    7,581
    Jun 4, 2015
    How much snow did you pick up between the two points?
    Unless you have a scale weight to go with your bag weight from Vermont, you're chasing your tail......
    Dominick253 Thanks this.
  5. STexan
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    All I know is my gauge reads almost 1000 lbs higher in wamsutter, WY than it did in St. Albans VT. Both times while sitting in a level scale platform. Same fuel, no ice either end, and it was properly calibrated to correct a 240 lb difference a week earlier at 700 ft MSL
    And No. There was not a "load shift". Everything was exactly where it was when it was loaded.
    I guess the moral of my story is that sometimes you can trust some of them and sometimes you can't.
  6. Big.D
    Big.D Bobtail Member
    21
    10
    Nov 9, 2015
    Eastern iowa
    Was perhaps your parking brakes set at one time and the other time they were not?
  7. STexan
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Nope. I'm always careful to make sure I'm where truck won't roll with no parking brake or pedal application.
    I haven't done an empty calibration in over 12 months. Maybe I need to start over from scratch. Will update thread as I can.
    Blackshack46 Thanks this.
  8. G13Tomcat
    G13Tomcat Road Train Member
    11,872
    42,143
    Jun 7, 2011
    Just the opposite, you weigh less at higher elevations. You are further from the earths center thus the laws of gravity come into effect. Any buoyancy effect due to the atmosphere is also reduced due to the thinner atmosphere, your body maintains the same volume but at higher elevation, due to the reduced density of the air you displace less air, thus once again weigh a bit more then at the bottom of the atmosphere. Both of these effects are so small that it is nearly impossible to measure them, unless you are in orbit.
    Reference https://www.physicsforums.com/threads/as-you-move-higher-on-earth-do-you-weigh-more.7862/
    Lepton1 Thanks this.
  9. STexan
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    I was kind of thinking in terms of the effects of altitude on air pressure in bags and on the pressure sensor. For an aircraft altimeter to be accurate, it must be set to the known real barometric pressure at the target airport [that is affected by high and low pressure systems that come and go]
    Like when you close an empty water bottle at 8,000 feet then take it to seal level, it's all crushed in on itself. But again, this may not even be a factor and maybe I just need to be more diligent in entering known empty weights more often then I have been. Altitude might affect the accuracy but probably very little. I suspect I have other issues going on.
    G13Tomcat Thanks this.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,818
    18,702
    Nov 1, 2010
    Burnsville, MN
    It's not the thinner air, it is less air pressure pushing in and down on you.
  11. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    It was definitely the bad enchiladas in Nebraska. Never eat enchiladas in Nebraska.
