after about 1100 miles this happened. The manufacturer uses a nylon band in the front and back to secure the transformer to the pallet. The front band failed on this transformer which almost led to 550 lbs of transformer escaping off the back of the load and potentially killing someone behind us.
We got it secured for the last 100 miles.
One of these things is not like the others….
Discussion in 'Questions From New Drivers' started by Nahbrown, Jun 15, 2024.
Page 1 of 4
Good heads up! I know it's s thank-less job, but THANK YOU for caring about the safety of the general crazy public motorists, and me! (If you see me out there, which is rarely)
broke down plumber, Grumppy, JolliRoger and 5 others Thank this. -
This is a TERRIFIC EXAMPLE...for others....of what to potentially expect....when doing flatbed duty.
GREAT SAVE there....
-- Lbroke down plumber, Grumppy, JolliRoger and 4 others Thank this. -
One would think that their should be a better way for the shipper to secure their product.
They used to lag screw them to the boards and the screws would split the wood.
Looks as if they found another cost saving Best Practice adding share holder value.4wayflashers, Kyle G., Flat Earth Trucker and 1 other person Thank this. -
My drivers would not be allowed to have that load on their truck without running another strap over the row. I am surprised that nylon strapping is even allowed as a primary means of tying it down on the pallet.
4wayflashers, JolliRoger, Albertaflatbed and 6 others Thank this. -
Sure seems like a cheap securement for what i would think is a relativity expensive piece of hardware .
Grumppy, JolliRoger, Kyle G. and 3 others Thank this. -
I HATE when that happens....
broke down plumber, Grumppy, JolliRoger and 1 other person Thank this. -
It shouldn’t be for flatbed freight, IMHO.broke down plumber, Lonesome, JolliRoger and 2 others Thank this.
IMHO the blocking is insufficient as well , maybe Thicker boards like 2x4s
broke down plumber, JolliRoger, Kyle G. and 1 other person Thank this. -
2x4s and real screws would do the trick, nails and pallet top wood is just not quite enough.
Better places use a stronger strap and better blocking, or have tabs to lag to pallet, cant strap over top of them.
1, would tip outside edges towards center loosening strap completely creating 0 securement
2, anything that messes with the integrity of the transformer top would result in exploding transformers when put in servicebroke down plumber and Flat Earth Trucker Thank this.
Page 1 of 4
