#### onions
Discussion in 'Flatbed Trucking Forum' started by porkchopski, Aug 7, 2015.
  1. porkchopski
    porkchopski Bobtail Member
    So I'm hauling onions from stockton ca to shelby oh. Tarpped the top. Sides front and back are breathing. And it's raining in wyoming. Talked to my boss he said as long as the top is covered I should be fine. But the sides and front gotta be getting wet. I don't wanna enclose the sides and front due to the posibility of cooking them. Will a little rain really cause them to rot? Second time hauling onions and I hate it.
  3. porkchopski
    Is it possible that they can dry up aftwr getting a little wet?
  4. rank
    rank Road Train Member
    9,918
    113,504
    Feb 11, 2010
    Ask @Skateboard. IIRC he used to specialize in onions. I think they paid by the ton and he loaded the cab too........you can't make this stuff up
    77fib77, S M D and MM3Deg Thank this.
  5. MM3Deg
    MM3Deg Medium Load Member
    354
    159
    Sep 23, 2007
    Fort Worth, TX
    Lol...
    "Hello, shop... Ya, I need a bunk installed in my sleeper"
    "a bunk? But your not a trainer or team??" "do you have a student?"
    "student?? No, I'm specialized in onions"
    Moving Forward Thanks this.
  6. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I've pulled a few onion loads out of New Mexico. My paper work said in bold red text.... DO NOT GET WET.
    I took a load to Fla and 2 loads to Mich. Both times I coverex the top and sides and left the rear open at the halfway mark. Just used a strap to hold the tarp up. This was in dead of the heat.. hot August. Flies all over the place when I got loaded and secured them. Thousands of them swarming and annoying me to no end.
    But I had no problems keeping the load covered and open in the back. That way if it rained.. at most they might get a little drizzle in there from the road spray.
    Hurst
  7. Big_Red
    Big_Red Medium Load Member
    439
    989
    May 5, 2011
    Not active
    When I haul them I leave the front open to allow circulation(rain or shine as I have a headache on my trailer). I leave the sides down all the way(rain or shine) and just don't bungee them as tight. The rear is the only one that I open and close. Delana farms out above Bakersfield requires that you haul them this way so I stuck to that and haven't had any issue. The cooking is an issue if you sit still for hours at a time. From what I know if they get soaked heavy and then get warm again they will start to develop a greenish looking mold/ fungus
  8. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Onions go in Reefers.
    Oscar the KW, Ruthless and MJ1657 Thank this.
  9. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    That explains all the reefer flats I see running across idaho with onions strapped to the deck.
    Landincoldfire and unloader Thank this.
  10. Cluck Cluck
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Those would be vented flats.
    07shaker Thanks this.
  11. shovel98
    shovel98 Light Load Member
    251
    241
    Jan 15, 2011
    mn
    Most reefer guys start getting bucky after anything past 43500lbs and shipper wouldnt get 4500lbs shipped for free. I pull both flat and reefer and you will never see a load of onions on my flat but then i dont haul them in reefer as they pay to low get better rate hauling tators. But then i dont haul lumber or steel in my reefer either.
    MJ1657 Thanks this.
