Ontario Dump Trucking business
Discussion in 'Ask An Owner Operator' started by konrodionov, Nov 5, 2016.
  1. konrodionov
    konrodionov Bobtail Member
    Toronto, Ontario
    Looking to get into dump trucking business in the Greater Toronto Area. A bit of background, I myself do not have trucking experience but have the ability to start off and manage different business as proven in the past. My partner is a full time long haul trucker, that will give us "some" exposure to the dump trucking business but not a whole lot.
    Have been a long time lurker but just joined the site today. I have been searching this site a lot as well as searching within the industry but still want to clarify a couple of things:
    - average hourly rate for driver and truck
    - average rate per load
    - typical payment terms
    - we are deliberating whether to start off with 1 truck or 2 trucks just to give us a better ability to service the customer's needs
    Understanding that there is a great deal of maintenance involved on used trucks vs. paying $$$ for band new - we landed on buying a serviced, certified used truck from a reputable, trustworthy source - Any recos? We will be going around dealerships in the next month but would be great to get some direction from the veterans. Looking to get tri-axle, min 400hp, at least 18.5ft steel box, 20,000 front, 20,000 lift and 46,000 rears - any direction on truck make would also be highly appreciated. Looking to spend under $80K per truck - reliability and maintenance cost is a key factor. If you are selling, send me what you have. Must be in Ontario.
    Would be interested in meeting or get in touch with some locals.
    Regards,
    Konstantin
  3. Ruthless
    Ruthless Road Train Member
    8,853
    87,019
    Aug 28, 2010
    The City.
    -What are your customers willing to pay?
    -Where are your customers loads going to/from?
    -Depends on the agreement you come to with your customers
    -Do(es) your customer(s) need more than one truck from you to service them?
    If your answer is "we don't have customers yet"
    Then you've answered most of the rest of your questions already.
    What you need for equipment is based on what tools your customer needs to be successful.
    How much they pay will be determined by what you offer and what you both agree to. Same as terms.
    SL3406, Dye Guardian and gokiddogo Thank this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,767
    Mar 5, 2012
    Ontario Canada
    Take a look around at who is running dump trucks around the gta. It has been taken over by the new Canadians. Everyone wants to do it because it is mostly very local work, it is similar to container work at us ports... it would be very hard to carve out a living in that market.
    Dye Guardian Thanks this.
  5. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    X2 on everthing gokiddo says plus this time of year would be the absolute worst time to buy a new dump truck. 75 an hour is as high as I've heard recently. I've never seen so many b/n kw triaxles as i've seen this summer. They gotta be pushing 200 g now in the spring id imagine you'll see a few at the big auction houses around here.
  6. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Hate to be direct here but if you have not figured out these simple things you are no were near ready to purchase a truck let alone two
  7. 6rider
    6rider Light Load Member
    107
    68
    Oct 24, 2016
    Ontario
    New here as well an was curious on the things you mentioned above. Anyone know if the big construction companies have a directory where they call up individual contractors as needed in Ontario? As Special K said it would be tough going to get into it right now before winter. Also heard the price of new triaxle tippers going north of 200k. That seems really risky to me (unless you have the capital). My advice would be to check out the Ritchie Bros site. They just had an action in Toronto (Bolton*) about a month or two ago and had a few triaxles up for action, the kind that you would be interested in. I think they had a couple Paystars Macks an such. They post the results so it could give you an idea of what you could expect to pay. As for specs in order to remain as competitive and open as possible you should probably spec 20 20 46 axles a 20 ft box 3.91 ratio and 475hp min. Get a transmission with a splitter to pull the hills ie 13 or 18. Back to box choices. Choice of aluminum or steel? Aluminum is great if you know your only going to be hauling non abrasive stuff like gravel. Steel is the best all around cause it could take just about anything hence remaining competitive. Just a few things to keep in mind. Maybe call some of the major construction companies offering your services like Michael Bros. I see them excavating a lot here in Toronto when there are new condos going up. Or paving companies like Furfari Gazzola... Good luck with whatever you do. It's a tough business these days. Maybe things will get better.
  8. GTA-Z
    GTA-Z Bobtail Member
    10
    Nov 12, 2019
    Sooo any updates here? How did things pan out, did you end up pursuing the dump route?
