Open and closable spread axels?
Discussion in 'Flatbed Trucking Forum' started by OneCosmicGuy, May 5, 2014.
  1. OneCosmicGuy
    OneCosmicGuy Bobtail Member
    27
    13
    Jul 28, 2011
    Mesa, AZ
    We're trying to take flatbed loads into Canada but need a trailer that will let us close the axles. Many provinces do not allow spread axles. I've made many calls trying to locate such a trailer but have been unsuccessful. Anyone know if such a trailer exists, what it's called, who makes it, etc? TIA
  3. Rugerfan
    Rugerfan Road Train Member
    7,272
    35,711
    May 3, 2011
    Redding,CA
    We pull Western's 48' spread axle trailers that have the back axles slide so they close up. I'm sure there are many other makes and models but that is what we pull at System
    OneCosmicGuy Thanks this.
  4. snowwy
    snowwy Road Train Member
    20,536
    13,272
    Jul 6, 2009
    Fontaine has front axles close back. 48 is what I pulled
  5. Boardhauler
    Boardhauler Road Train Member
    1,711
    3,477
    Dec 21, 2008
    Ballin' in it for Shakey
    A friend of mine has a 45' Wilson that is set up so that the front axle will slide back & make it a closed tandem.
  6. fortycalglock
    fortycalglock Road Train Member
    6,151
    6,583
    Jun 25, 2011
    Tourist Town, FL
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Reitnouer make them along with the others mentioned.
  8. beastr123
    beastr123 Road Train Member
    2,838
    23,227
    Jan 2, 2014
    Moose Jaw SK CAN
    front axle slider moves weight onto the drives (approx 1700#) when you close up,
    but you can run 37500# on a tandem in Canada.
    when I pulled a 48' step front slider across the border I could load 12000/ 37000/ 37000 in
    Canada then after sliding fifth wheel and axle I scaled 12800/ 33800/ 39400 in the
    north-western US
    a rear slider does the opposite and can't be used in the same way, but has the
    advantage of changing you trailer wheelbase on a 53' trailer
    OneCosmicGuy and Cetane+ Thank this.
