Opening and Closing a Spread Axle Trailer
Discussion in 'Flatbed Trucking Forum' started by Blind Driver, Jan 31, 2013.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I'm wondering what is the proper procedure to move the rear axle. I had assumed there would be a way to either lock the brakes on the rear axle or to dump the air from the front axle. I was told to apply the parking brake, unlock the pins, then pull on the trailer. It may not be much, but the front tires will have to slide on the road/parking surface. This seems like unnecessary wear on the tires?
    Any better ideas?
  3. Rugerfan
    Rugerfan Road Train Member
    7,618
    38,587
    May 3, 2011
    Redding,CA
    there should be a button on the trailer to lock the back axle so you can slide it. at least there is on the trailers at my company. maybe block the back tires and see if that maybe is less wear on the tires?
  4. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I'll look again. Should be easy enough to put a valve on the airbag line to the front axle.
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    Several PITA ways to avoid dragging the tires.
    Cage the brakes on the fwd axle.
    or
    Use a ratchet binder and a chain from the axle to the bumper if you are worried about your boss's tire wear.
    Me? I'd just drag 'em.
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    If it's a company trailer, ask them how they want it done. If they dont care about the tire wear, then that is their call IMO.
    Easiest way though, if it has neither of the above, is to dump all the air, then pinch off the airbag lines to the front axle with small vice grips etc, then slide it. Years ago, I installed an inline fitting with a quarter turn valve built into it. This allowed me to dump the air, turn the 2 knobs a quarter of a turn, and air the other axles back up.
    Lot quicker than caging brake chambers or chaining an axle up.
    Martin
  7. Semi Crazy
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    If you don't mind crushing your air lines...
    blind driver might be dedicated enough to spend money on valves for his boss's trailer before he even gets paycheck no. 1, ya never know.
  8. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    My trailer you set the tractor brakes but mot the trailer, then you just turn a valve that sets the brakes on the rear axle, and airs up the bags all the way (raises trailer) and you pull a knob that releases the pins (air pins) then u just pull forward.
  9. the gambler
    the gambler Medium Load Member
    330
    245
    Feb 14, 2011
    Kentucky
    What brand trailer is it? On the older Transcrafts we have, you supply air to the trailer and there is a lever on the rear axle to lock the breaks on that rear axle. On the newer ones there is a valve on the outside frame well just behind the center pout of the trailer.
    SHC Thanks this.
  10. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    Not ideal for the 1/4" airlines granted, but they will spring back as a rule, where tread on tires wont!
    As I said, it's his bosses call IMHO.
    Martin
  11. SHC
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    It's a 2012 Fontaine Infinity AX. I'll snap a pic of it tomorrow since I have to open it up for the 45k I'm loading.
    the gambler Thanks this.
