Opposed piston heavy duty Diesel engine?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by iceman32, Sep 27, 2018.
  1. Tb0n3
    Tb0n3 Road Train Member
    4,519
    8,862
    Oct 5, 2012
    Earth
    It seems to be a similar system to the Detroit two strokes. I always thought they were pretty interesting.
  3. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,542
    May 22, 2017
    The 2 strokes still used a valvetrain. So opposed is even more simple.
  4. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    Uh two cranks and twice the connecting rods and pistons isn't really going to add up to fewer parts I don't believe. The old 350 cummins had about 1400 or so and 318 Detroit's had about 1300 or so, yes they pulled 80,000lbs, not many of the truck drivers today could drive them. It's just more trying to fix what aint broke thats all.
    Oldironfan Thanks this.
  5. Snoopycda
    Snoopycda Medium Load Member
    361
    715
    Jan 22, 2016
    Edmonton Ab.
    If you want instant torque look at diesel electric. Weight and space also need to be considered though.
  6. Tb0n3
    4,519
    8,862
    Oct 5, 2012
    Earth
    I've always thought that'd be the best solution for efficiency. Maybe it'd just be too heavy. Replace the transmission with a generator and differentials with electric motors. Something like that.
  7. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    It would be other than I don't know how well electric motors would put up with nasty stuff that gets put on the roads for deicing, it just eats any copper it can get to.
  8. midgetripples
    midgetripples Light Load Member
    139
    89
    Sep 16, 2018
    2 strokes do not have a valvetrain because they do not have valves
    Tb0n3 Thanks this.
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,134
    Mar 5, 2016
    White County, Arkansas
    We had a opposed piston Farmall at the horse farm. It had a torque that cannot ever quit. If you tied the earth to it, it will try and stop the rotation of the planet.
    But it had no lungs. Once you ran out the gear it was in that's all you get. It turns into a fuel burn per hour problem. How much field can you run with that little bit of fuel in that tiny gear you are in for the day?
    This is not a bash on opposed piston technoloy I like them. But horse power is king. Torque is all well and good provided it's at least 1800 pounds foot to the drive shaft and not casterated. But horses, the more you have say 750 to 1000 like they use in german tanks... the less fuel burn per hour in terms of practical work you have to do lifting that trailer over the mountain to say 14000 over loveland pass. It wont work so hard like a poor little 280 mack or something from the 60's
    That's my thought on opposed piston. If you can gear it fast enough to be worth a #### at 70 against headwinds and minor rolling midwest hills etc then have at it. Im interested in learning what such a beast would do with 335 gallons of fuel in 80000 pounds on a schedule.
    iceman32 and Oldironfan Thank this.
  10. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    8V92 Detroit. I see cam gear and exhaust valves....
  11. midgetripples
    139
    89
    Sep 16, 2018
    i stand corrected they must have had an oddball 2 stroke that they trained me on in the army cause it did not have valves
