Optimized idle
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Viking84, Jan 7, 2009.
  1. Viking84
    Viking84 Light Load Member
    197
    86
    Dec 27, 2008
    Valdosta Georgia
    I am still in CDL school, and do not know the terms of trucking yet.
    I am looking at Hunt transportation, and was told that their trucks run optimized idle.
    Help a newbie out and please explain what that means?
  3. Baack
    Baack Road Train Member
    15,294
    10,174
    May 24, 2007
    Wisconsin
    Optimized Idle with DDEC III/IV reduces engine idle time by running the engine only whenrequired. Optimized Idle automatically stops and restarts the engine to accomplish the following:- Keep the engine oil temperature between factory set limits 60�F (16�C) -- 104�F (40�C)- Keep the battery charged >12.2 V (12 V system), >24.4 V (24 V system)- Keep the cab/sleeper or passenger area at the desired temperature (using the optional thermostat)
    Wajid8705 and panhandlepat Thank this.
  4. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    It turns the truck on and off, while your stationary. To maintain temp control in the cab.
    Many are set to save fuel now. 5 minute max time. So they aren't what they originally started out to be. More of a nuisance now.
  5. brinkj23
    brinkj23 "Asphalt Cowboy"
    1,165
    322
    Dec 26, 2005
    Minnesota
    Yeah they are annoying as heck, my truck has it and for the first couple weeks or so I woke up ripped the curtains open thinking someone was stealing the truck or someone just hit me. But I figured out a way to keep the truck running constant. I feel its a safety thing cause I need a comfortable sleep with no annoying wake ups every 10 minutes, cause im a light sleeper and even after two months of it I still woke up every time it started up and turned off.
  6. He who is called I am
    He who is called I am Medium Load Member
    437
    98
    Dec 18, 2008
    Da U P Eh, Michigan
    Im glad i dont have that. Im a light sleeper as well. That must be hell not being able to get a good nights sleep.
  7. mtorr
    mtorr Bobtail Member
    7
    Miami, Florida
    Hi I just purchased a truck with a detroit engine and it has Optimized Idle. Does any one knows how to use it? I've tried to make it work but it seems I doing something wrong.
    Thanks
  8. brinkj23
    1,165
    322
    Dec 26, 2005
    Minnesota
    On the truck i had, you turned the truck off and flipped the switch that was on the dash board then you had to turn on the box that was in the sleeper and set the heat or ac on that. But if you bought it and dont like it I would disable it, I went through two starters on the volvo I had with opti idle, its very hard on the starter starting the truck every 10-20 minutes.
  9. rschweizer
    rschweizer Bobtail Member
    How did you disable it?
    RS
  10. brinkj23
    1,165
    322
    Dec 26, 2005
    Minnesota
    I didnt disable mine I just figured out a way to confuse the truck to think it was still in gear so it wouldnt shut off when I parked. I just put the range selector in high range and put it in front of the final gear there is a spot just before it goes into gear so the computer thought the truck was in gear when it really wasnt, thus keeping the truck from shutting itself off.
  11. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    u can turn opt idle off in the ecm and disable idle shutdown. sometimes u will have to change the in and outs too..
