Orientation Driving Test - Do Most Companies Allow Practice Time?
Discussion in 'Questions From New Drivers' started by Zoltan1a, Jul 28, 2012.
  1. Zoltan1a
    Zoltan1a Road Train Member
    1,254
    1,510
    Mar 15, 2011
    Las Vegas, NV
    Do most companies allow practice time prior to these driving tests? I did not drive a Porsche in school and I am certain these company trucks will a bit better and take some time adjusting to. I am going with Roehl
  3. Giggles the Original
    Giggles the Original Road Train Member
    not that i am aware of....they figure you should have learned that in school...not being rude..
  4. Zoltan1a
    1,254
    1,510
    Mar 15, 2011
    Las Vegas, NV
    Shoulddddd! but they should know better.
  5. Zoltan1a
    1,254
    1,510
    Mar 15, 2011
    Las Vegas, NV
    Are they looking for perfection on this test? I just cant imagine traveling to orientation and have to turn around because of a quick drive test.
  6. ncfinfn
    ncfinfn Bobtail Member
    6
    When I went to oriantation with usx I hadn't driven a manual in 5 yrs.You don't think I didn't grind gears a bit,and I passed.Don't sweat it you'll get most of that experiance with your trainer anyways.
  7. trips74
    trips74 Medium Load Member
    367
    217
    Nov 7, 2007
    chicagoland, il
    they never that im aware of allow practice for road test, biggest advice dont be nervous and just remember the basics. if you get into a newer truck to road test it should be easier and smoother then the school trucks. Just keep it simple and follow signs and rules of the road youll be good....
  8. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    no
    very close to it...!!!
  9. vinsanity
    vinsanity Road Train Member
    1,760
    689
    Nov 23, 2009
    South Florida
    Training companies aren't looking for perfection. They just want to make sure you can sort of operate the vehicle safely. Keep it between the lines, don't hit any curbs, use your signals, etc.
    It's a different ballgame for experienced drivers.
  10. Guitar Man
    Guitar Man Medium Load Member
    553
    467
    Sep 29, 2006
    State Of Confusion
    Then I'm pretty sure the truck your going to test out in won't be a helluva lot better than the one you learned in. 8>)
  11. Klatu
    Klatu Road Train Member
    1,039
    230
    Nov 26, 2010
    Argyle, TX
    just remember. If you keep it in gear there is less grinding.:biggrin_25519: Also, They are not looking for that. They want to see how you take corners, right hand turns, speeding, leave your blinker on until you are fully in your lane. Stuff like that. Do not shift while going over a RR track. They also like it if you "TAKE YOUR TIME". Go slow. Don't give them a reason to be nervous. I've had many compliments because I didn't scare them.
    Female Driver Thanks this.
