Orientation-Neck Measurement?
Discussion in 'Schneider' started by FL CottonTop, Feb 27, 2018.
  1. FL CottonTop
    FL CottonTop Bobtail Member
    Feb 22, 2018
    I am about to go to Schneider orientation in Atlanta, Has anyone been recently? I am concerned about my neck size. I am very healthy but extremely overweight . I was wondering if they measure your neck and what they might do since I do have a big neck. I do not have sleep apnea.
  3. shogun
    shogun Road Train Member
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    I think it’s standard DOT medical card practice to measure your neck nowadays. I had mine measured last June for the first time. I am fairly muscular having powerlifted for a long time, so my neck is big. However, I mysteriously passed and I can only assume because the nurse knew I wasn’t overweight.
    Schneider won’t measure it, but they will at the physician. Everyone I know who has updated their medical card in the last year has been measured. They also stuck a pulse oximeter device on your finger and measure your oxygen concentration. That was new to me too. I don’t not drive for Schneider, just am commenting on the changing trend. Your results may vary.
  4. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    Extremely overweight and Very healthy? Leprechaun?
    elamigowapo and Puppage Thank this.
  5. Camera66
    Camera66 Bobtail Member
    9
    4
    Feb 25, 2018
    If you're already aware that you have sleep apnea, should you bring your CPAP's SD card (or just print out the contents) to the physical with you so they can check it?
    Edit: and not to hijack but I mean any DOT physical.
  6. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Only scam companies force that cpap scam,they get a kickback somehow.
  7. Dave_in_AZ
    414,253
    17" ( FAT ) neck or bigger, if you're over weight, you're going for mandatory sleep study.
    Opus and Steel Dragon Thank this.
  8. mindes
    mindes Medium Load Member
    626
    540
    Feb 17, 2015
    Crestview, Fl
    I went to ATL Schneider orientation in '15, at that time they did not measure anyone's neck. After being a month on my own, I came back in for check for making sure you are doing it the Schneider way. With that, I filled out an online survey about sleep. Got picked for a sleep study a month later and passed.
  9. Brandt
    Brandt Road Train Member
    4,604
    6,324
    Sep 17, 2012
    Extremely overweight and maybe a big neck. Sounds like they will have you do a sleep test. Since you already know you don't have sleep apnea you got nothing to worry about. The test is free just like the D.O.T physical.
  10. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    not sni. if your study shows you have apnea, they give you a loaner machine til ins kicks in. then EVERYTHING is paid for. ZERO driver out of pocket. EVER.
  11. Opus
    128,885
    Yep
