orientation Q
Discussion in 'Questions From New Drivers' started by cliffrid, Dec 25, 2012.
  1. cliffrid
    cliffrid Bobtail Member
    7
    Dec 20, 2012
    Dallas, TX
    If you've been accepted to an orientation, do you basically have the job-assuming you pass the tests and physical?
  3. bob the trucker
    bob the trucker Bobtail Member
    49
    15
    Dec 15, 2012
    yes, depending on wether they want drivers or are just looking for a few good men
  4. pokerhound67
    pokerhound67 Heavy Load Member
    801
    665
    Oct 30, 2012
    yes. the things that could change that to a no are... drug test, physical, road test, and your application. if something is found to be untrue, theyd be likely to change their mind about hiring you. but theyve checked everything before asking you to come to orientation. only reasons i could think of for finding new info would be if someone called them back because they wanted to clarify something or had a change of heart (very unlikely) or if you added some info you hadnt disclosed on your app. basically whether you get hired or not is completely in your control as i see it. assuming you can physically do the job you said you could, and dont have drugs or alcohol in your system (do yourself a favor, if youve done drugs in last 30-60 days,put orientation off. same with alcohol in last 24 hours) then you have nothing to worry about...other than a blood pressure or blood sugar condition you were unaware of. road test sometimjes is limited to backing into a dock and doing the vaguest of pretrips, other times theyd actually go out on the road, but either way its very easy for an experienced driver. good luck with the new job!!!
  5. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    Nope. There are many reasons you could be sent home. Cr England doesnt run your dac report until you are at their facility. Many guys sent home for something being on dac. So short answer is no the job isnt ever guaranteed. Even recruiters will say "You should be alright when you get here" but they wont say "Its possible you would get sent home. Seen it too many times.
    Trucail Thanks this.
  6. snowman01
    snowman01 Road Train Member
    1,246
    713
    Sep 27, 2011
    North Carolina
    yes and the background check.
  7. Allow Me.
    10,677
    12,240
    May 28, 2009
    Rancho Mirage, Ca.
    It's almost safe to assume you're OK, however, you're not hire until you get an employee number and the keys to your truck.
  8. Trucail
    Trucail Medium Load Member
    611
    294
    Oct 27, 2011
    Seattle, WA
    They could make up any reason to send you home. Again most don't even run the reports until you get there, so they don't even know.
  9. bob the trucker
    49
    15
    Dec 15, 2012
    remember also if not hired its up to you to get home
  10. jessi12
    jessi12 Light Load Member
    102
    1,081
    Sep 11, 2012
    Louisville, KY
    Many companies are not going to waste money bringing you in if they are not fairly sure they're going to hire you. Some will, but most won't. But just because you are at orientation doesn't mean you are hired. If you fail the physical, road test, drug test you can be sent home.
  11. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    There are recruiters that will send you to orientation just so they can get paid.
    As long as you were honest on application and your background, MVR and past employers are all good then you should be ok. Like Allowme said, until you get your keys to your truck is probably the actual time of employment. Most companies have 90 day probationary periods so there is that to throw into the equation.
    During orientation you will have a road test and then days of paperwork, movies, tests and safety crap. A lot of companies now give wellness exams too. During this time you will be given a one on one job interview with indian chief so make sure to dress nice during orientation. You don't have to wear a suit and tie but nice pants/clean jeans, nice shirt, either collared or button down etc... Leave the sweat pants and pot leaf hat at home! (on my fathers grave we once saw a guy wear this to orientation at our company!) These people don't know a lot about you so this is the time to impress them and show them who you are. You are going to be essentially representing them when dealing with their customers and you want to reassure them that you are the person for the job. Believe it or not, I have actually been told from the source that this is a factor when issuing trucks! The nice, newer, clean trucks go to the folks that show they will take care of them. The drivers they believe are going to stay around for awhile are usually more invested in.
    Just a heads up, your peepee test and blood pressure test etc... are given the first day and usually first thing in the am. If your blood pressure is high or close to high you may want to avoid coffee and/or soda that morning. High blood pressure will get you sent home just as fast as a positive peepee test!
    Make sure to bring everything you will need for the next 2-3 months to orientation. Chances are you will get home sometime before then but just in case you will be fully prepared. With that being said you also don't want to overdo it! You will be going with a trainer most likely after orientation is through and it could be a tight fit! You aren't going to a third world on a church mission so if you leave anything behind or forget something you can easily pick up at Walmart or worse case scenario, a truck stop.
    Some things new drivers forget to bring: work gloves, birth certificate, license, social security card, medical card AND LONGFORM! Blank check for direct deposit, knife, small flashlight, emergency money (not everything goes according to plan and if you end up on the side of the road or kicked out of your trainers truck you won't be stranded! Also companies do not pay your way home if you do not make it past orientation) cell phone charger, a few pens and notebook, and anything else I forgot to mention. Make yourself a list and check it off as you pack!
    Besides this stuff it is a really good idea to have a nice resume prepared ahead of time to take with you. Not only is it impressive and shows your sincerity and dedication but you will have to fill out lots of paperwork and it will be real handy to have for copying or remembering information.
    Things you don't necessarily have to bring: Towels, soap, sleeping bag (you can make your own bed roll with a sheet, blanket and pillow. I find it works better then a sleeping bag.)
    Multiple pairs of shoes (for now try to wear a nice versatile pair of shoes to cut down on what you pack) cleaning supplies, food, computer/laptop, passport, cooler, suitcase, electronics for the truck such as CB, satellite radio, gps. (wait until you are assigned a truck) Be sure to not over pack clothes. A couple pairs of jeans and handful of T's, socks, and briefs. A good sweat shirt and jacket. You should have many opportunities to do laundry so don't go nutz on packing clothing. Bring what you think you will need just try not to overdo it. Once you are issued your truck you can go nutz! Also you will have a better idea of what you need to survive out there.
    Good luck man...
    cleanbyrd Thanks this.
