OSHA requirement?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lazer, Mar 26, 2021.
  1. Lazer
    Lazer Road Train Member
    1,830
    2,939
    Jan 22, 2017
    Not sure if is the correct group for this question, but here goes= Is it an OSHA requirement for air conditioning to be operational in a class 7-8 vehicle, operated by an employee?
  3. kemosabi49
    10,909
    47,350
    Jan 13, 2013
    SW Arkansas
    No. But the FMCSA does require the defroster for the windshield to work. They don't care if you sweat.
  4. AModelCat
    161,539
    No. I hardly ever use A/C.
  5. Lazer
    1,830
    2,939
    Jan 22, 2017
    That’s true, in modern vehicles when you switch to defrost, the a/c compressor kicks in. If the compressor does not kick in, is the defrost system still considered ‘operational’?
  6. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    If it has it from factory it needs to work in order to pass a DOT/MOT safety inspection but OSHA doesnt care.....
    MTN Boomer Thanks this.
  7. D.Tibbitt
    153,210
    This is all wrong info. None of the safety systems need to work to pass a dot inspection, neither do all the lights.
    God prefers Diesels Thanks this.
  8. kemosabi49
    10,909
    47,350
    Jan 13, 2013
    SW Arkansas
    Not true. The nanny systems, extra lights do not have to work. If they are not required equipment per the Green book, they do not have to work.
    As far as the A/C kicking on with the defroster, again, the FMCSA doesn't require it. 393.79 only requires a defroster. Incidentally, they do not require a working heater in the truck. Only the defroster.
  9. AModelCat
    161,539
    @Flint1 what's the book say on A/C needing to work to pass a CVIP?
    I'm going to assume no since I had a company truck pass CVIP with the A/C broken.
    Flint1 Thanks this.
  10. 6cuda6
    259
    176
    Oct 9, 2020
    I stand corrected. Perhaps its not required where you are but i know it is were i'm from.
  11. D.Tibbitt
    153,210
    These are federal regulations, not state. If u got violation for one of those then they were wrong.
    p608 and God prefers Diesels Thank this.
