Out of Service
Discussion in 'Ask An Owner Operator' started by JonasTtrucker, Sep 3, 2018.
  1. JonasTtrucker
    JonasTtrucker Light Load Member
    53
    Apr 26, 2018
    St. Louis, MO
    I haven't driven for any of the big companies (Landstar, Schneider, Swift, etc) so just curious if you happen to be put of service at a weight station or roadside inspection what do the companies require of you afterwards?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If its something wrong with your truck or trailer, you must turn in the signed repair OOS form and tic. for any $ paid to fix truck, CO. can fire you, or if you work for white vol. club they may fine you?
    jsnell Thanks this.
  4. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    The WV club is scary. Tiny DOT numbers and no markings anywhere including the trailer.
  5. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    One of the biggest things they will require of you is that you contact them Immediately so they can make other arrangements on the load if they feel its necessary? Obviously, one of the other biggies is that you do whatever you need to do to help insure it doesnt happen again.
  6. Ridgeline
    22,469
    117,833
    It depends on why you were put out of service, if it was a driver thing, then talk to safety. If it was a truck issue, then correct it and prove you did, if it is a load issue, fix it on site.
    bullhaulerswife Thanks this.
