Outlet NOx Sensor trouble SPN 3226 FMI 9
Discussion in 'Peterbilt Forum' started by JKtrash, Mar 2, 2015.
  1. JKtrash
    JKtrash Bobtail Member
    I have a 2013 Peterbilt 320 and I am coming up with aftertreatment outlet NOx sensor - abnormal uprate. no communications or invalid data transfer rate detected on the J1939 data link between ECM and the aftertreatment outlet NOx sensor SPN 3226 Fmi 9 Cnt 1
    we changed the NOx sensor near the exhaust stack (which we assumed to be the outlet sensor) but the same code keeps coming up. does anyone have any ideas as to where to look to solve the problem?
    we also got an engine protection Torque Derate SPN 1569 FMI 31 Cnt 1 which I assume is due to the above issue.
    Thanks!
    John
  3. Belials
    Belials Light Load Member
    232
    214
    Jun 10, 2014
    Being that this is a 2013, are you sure you don't still have engine warranty?
  4. JKtrash
    I do have a warranty, however the dealer is a few days out from being able to look at it and I need the truck back asap. thought it would be a simple sensor change.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,512
    Dec 29, 2008
    Northridge, CA
    check the wires from Nox to ACM (aftertreatment control module)...
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    FMI 9 - sensor reads too much NOx in exaust, electric problems are FMI 3 ore 4.
    So try to replace sensor, it may be incominatade with exust ash
  7. JKtrash
    We replaced the sensor already, but no avail. had to send to dealer. Turns out, the fuse box was corroded in the cab of the truck. they said it was a known peterbilt problem, but since it was over a year old, not covered under chassis warrantee!
