Outside Temp. Problem
Discussion in 'Kenworth Forum' started by 325TahoeSS, Jan 2, 2016.
  1. 325TahoeSS
    325TahoeSS Light Load Member
    150
    71
    Feb 11, 2012
    Roma, Tx
    i have a 2007 w-900 KW that a few days ago my outside temp. gauge reading is like 25 degrees above what the actual temp is! How can i fix this? its driving me nuts not to know how cold or hot it is outside! On my truck it reads the temp. on the dash, on the rpm gauge. thanks in advance!
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Sometimes if you're not moving and the wind is blowing toward wherever the temp sensor is, it will move engine heat in that direction. Otherwise, I'd assume there is a sensor problem
  4. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    Id like to find out where the sensor is to change it! When I'm driving it'll show 75 degrees and its like 50 outside
  5. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Pretty sure it is in the bottom of the drivers mirror.
  6. 325TahoeSS
    150
    71
    Feb 11, 2012
    Roma, Tx
    so what your telling me is that the sensor is in the drivers side mirror? inside the mirror?
  7. Deputy Chief
    Deputy Chief Light Load Member
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
  8. Deputy Chief
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
    Maybe that will help, or do what we all do......Google it! That's how I find everything.
    325TahoeSS Thanks this.
  9. Steve62
    Steve62 Light Load Member
    170
    98
    Mar 5, 2015
    Northern BC
    I just changed mine, it is a small sensor on top of the mirror.
    The plug looks like a phone cord plugs into the back of the gauge.
    That was on a 2006 KW t800.
