Over 10,000 and under 26,000 out of state
Discussion in 'Trucking Industry Regulations' started by deathB4decaf, Feb 13, 2020.
  1. deathB4decaf
    deathB4decaf Medium Load Member
    605
    872
    Jan 10, 2018
    There is a van body that I need to have delivered out of state. Over 10k and under 26k. Does the unit need a permit that is hauling the load? Everything I typically deal with is over so I just use our IFTA fleet trucks. This particular driver doesn't have his CDL and therefor, cannot drive our larger units.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,141
    Mar 5, 2016
    White County, Arkansas
    A van body?
    Like say a A team Van van?
    Or some other van truck body?
    What truck do you intend to load that on?
    Sorry for questions, but without details I cannot understand the question.
  4. deathB4decaf
    605
    872
    Jan 10, 2018
    I'm still new to some of this. It is the van body off of a truck. Thinking about using a rollback.
  5. x1Heavy
    34,017
    42,141
    Mar 5, 2016
    You are probably going to get into a special kind of trailer called a Landoll. It lowers down as a ramp, put the body on it, secure the bejeezus out of it and if it's over size get permits. And proceed.
  6. deathB4decaf
    605
    872
    Jan 10, 2018
    So, we can't use a rollback? It will fit on our rollback. We have a Landoll that we use for 40' containers but that would require someone with a CDL.
    x1Heavy Thanks this.
  7. deathB4decaf
    605
    872
    Jan 10, 2018
    I'm just wondering if I need permits to take a unit out of state even though it is under CDL.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    Only need permits if the rollback is three or more axles.
    Two things come to mind though. One would be height. Make sure it stays under the 13'6" required. Two would be weight. Make sure the rollback would still be under 26k lbs loaded.
    deathB4decaf Thanks this.
  9. wis bang
    wis bang Road Train Member
    3,428
    4,066
    Jan 12, 2011
    Levittown, PA
    The van body has no effect on the CDL nature of the roll back.
    Either the roll back requires a CDL or it does not...payload is immaterial except the height as an MT van body doesn't weigh much in the first place...
    Still needs his Med cert over 10K.....
    x1Heavy and deathB4decaf Thank this.
  10. ZVar
    10,911
    23,830
    Sep 10, 2010
    Flint, MI
    Payload weight does matter if it pushes it over 26k actual weight.
    Not only would the truck be over weight, the driver can be put oos for driving without a license.
    wis bang and deathB4decaf Thank this.
  11. deathB4decaf
    605
    872
    Jan 10, 2018
