Over weight help?
Discussion in 'Questions From New Drivers' started by TruckingSexy, Mar 21, 2018.
  1. TruckingSexy
    TruckingSexy Light Load Member
    73
    29
    Nov 2, 2017
    11,900lbs steer tires 35,800lbs on drive 31,000lbs on trailer. 5th wheel all the way up and trailer tires all the way up. Tank 1/2. Moving from Houston TX to Memphis TN. Anyway to get around this without needing to be reworked?
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    moving fifth wheel only helps steers. to much on the noise.
    Grumppy Thanks this.
  4. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    I’d roll with it but that’s just me. May have to have it reworked. Or you could jam it into reverse, mash the throttle then slam on the brakes.
    jammer910Z Thanks this.
  5. Moose1958
    Moose1958 Road Train Member
    15,136
    33,292
    Dec 17, 2010
    Williesburg, Virignia
    It's been several years but to go from Houston to Memphis in general you can go up US 59 to I 30 then on to Little Rock and east on I 40. However your going to have problems with the Hope Arkansas scale. I suggest you rework it.
    TruckingSexy Thanks this.
  6. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    i agree too.
  7. Moose1958
    15,136
    33,292
    Dec 17, 2010
    Because it has been so dang long since I crossed those Hope Scales I can't remember which is which. your under total gross and over 1800 on your drives. I can't remember if that dang scale is a super coop are just one with an older static scale. If it's an older static scale I would just run with it. Unless Arkansas has that east bound scale in West Memphis operating the Hope Scale is all that is in your way. (of course just as soon as I hit post someone will report another scale in Texas operating on US 59.)
  8. Woodchuck88
    Woodchuck88 Medium Load Member
    553
    1,103
    Jan 4, 2017
    New York
    1. get it reworked 2. Go around scale house 3. Pay the fine but they might not even pull you around for that.
  9. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Anyone know what happens if you cross a scale like this and cannot get the axle weights legal? Do they make you rework it there or just give you a ticket and away you go?
    SingingWolf Thanks this.
  10. b61mack
    b61mack Light Load Member
    60
    70
    May 18, 2010
    port murray nj
    run it, as long as you are under 80k, i run over on my trailer and the only scale that will flag me is winchester VA, i run TX to nyc.
  11. Woodchuck88
    553
    1,103
    Jan 4, 2017
    New York
    They are building a new one just south of nacogdoches on the northbound side I believe.
