Over width load
Discussion in 'Questions From New Drivers' started by kaschnabel20, Oct 13, 2017.
  1. kaschnabel20
    kaschnabel20 Bobtail Member
    5
    Oct 13, 2017
    Maybe a stupid question but a serious one at that. I'm picking up a 12' 2" load. When I measure do I include my chain and securement plate in the measurement? Or is it just the load itself?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Just the load itself. But I always add a few inches to be safe.
    Lepton1, SAR, LWT104 and 2 others Thank this.
  4. Truckermania
    Truckermania Road Train Member
    1,166
    1,754
    Oct 13, 2011
    Sturgis,SD
    Anything that adds to the width of the load should be measured. You can always add a couple inches width on your permit if needed as long as it doesn't put you into extra requirements (such as pilot cars for example).
    LWT104 and kaschnabel20 Thank this.
  5. Truckermania
    1,166
    1,754
    Oct 13, 2011
    Sturgis,SD
    If a Mod would move this to the heavy haul sub-forum you might get more answers.
  6. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    Legaly, you don't have to add securement to width. Chains, hooks. Depending on the states your going to run in, being over 12 ft. May require pilot car or cars.
  7. kaschnabel20
    5
    Oct 13, 2017
    I have to have an escort over 12' in CA anyway, so it doesn't really matter, but I want an accurate measurement for myself.
  8. Truckermania
    1,166
    1,754
    Oct 13, 2011
    Sturgis,SD
    Very true but I have had times when every little width was measured and ended up having to get a new permit and get rerouted. Arizona, for example, once managed to turn a 12' width load into a 13 1/2' width load.
    Crude Truckin' and TripleSix Thank this.
  9. TripleSix
    129,661
    It does matter. Never say that it doesn't when someone tries to help you. @superhauler told you correct. Just because the state requires one thing doesn't mean that you got it down pat. You may be required to get local permits if your destination is down some county road or city street. 12'2 would require a police escort besides the civilian in certain metro areas.
    Lepton1, SAR, Crude Truckin' and 2 others Thank this.
  10. kaschnabel20
    5
    Oct 13, 2017
    ####, calm down dude, I appreciate and respect the responses, forget I posted this.
  11. Broke Down 69
    Broke Down 69 Road Train Member
    2,733
    9,772
    Jul 3, 2016
    Concord NC
    You just cussed and spouted off to one of, if not the most, respected heavy haulers here. I expect advice for you will be pretty much non existent from here on out.
    Lepton1, SAR, Crude Truckin' and 4 others Thank this.
