So, I changed this valve yesterday. Quick process, part was $41. The problem now is that I keep getting a code for fuel feed electrical fault mid 128 pid 94 fmi 3. This isn't making sense to me. It comes and goes, 34 times in 2 hrs. Any ideas?
Overflow valve d12
Discussion in 'Volvo Forum' started by Helowrenchturn2, Mar 14, 2014.
Were you able to fix your problem I have same problem so far they change fuel pump accessories drive and fuil filter housing h
They even supplied fuel directly from bucket and still no fuel pressure tks in advance .sam -
MID 128 PID 94 Fuel delivery pressure
In addition to the fuel pressure, the sensor also measures the fuel temperature.
Component: (B51) Fuel pressure/temperature sensor
Fault code
FMI 3
Short circuit to battery voltage.
- Condition for fault code:
- The voltage of EA27 exceeds 4.95 V.
- Possible cause:
- Short circuit to battery voltage, signal cable.
- Fault in sensor.
- Reaction from the control unit:
- Fault code is set.
- Yellow light requested.
- Noticeable external symptoms:
- Yellow lamp lights.
- Appropriate check:
