Overhead powerline clearence for gravel roadway
Discussion in 'LTL and Local Delivery Trucking Forum' started by vickeybear, Aug 14, 2014.
  1. vickeybear
    vickeybear Bobtail Member
    4
    After making a delivery, my husband was traveling on a gravel road (public road) in Missouri and hit an overhead power line taking it down. The Utility company service man told him he didn't think it was his fault because the power line should have been higher. He was also told by nearby residents that semi trucks have traveled on that road before. There weren't any signs of low clearance. The company he works for had him fill out a report. How do I find out what the minimum clearance requirements are? Has anyone had any experience with this? I just want to have my bases covered incase the company comes back on him for damages or even fire him for it. My personal opinion is that it put my husband in a very dangerous situation and there should be regulations about the height of power lines over roadways but my opinion doesn't hold much water if I can't back it up.
    Any advice is very much appreciated!
    Thanks,
    Vickeybear
  3. snowwy
    snowwy Road Train Member
    20,527
    13,265
    Jul 6, 2009
    it was discussed on here once before, a few years back.
    14 feet if it's a truck traveled road.
    were there any warning signs about truck clearances?
  4. okiedokie
    okiedokie Road Train Member
    11,814
    86,130
    Jun 13, 2011
    PNWET
    Around these parts it's 15ft. Call the Power company. I bet it's been down before.
    A little looking on the Net.
    When we move up to power lines over public streets, roadways without truck traffic and alleys, with voltages of 300-600 volts, a minimum clearance of 15' is required.
    And for power lines over alleys, public streets, non-residential driveways, roadways with truck traffic, with maximum voltages of 600 volts, a minimum clearance of 18' is required.
  5. FLATBED
    FLATBED Road Train Member
    NATIONAL ELECTRICAL CODE ( NEC ) Suggested for power lines over alleys, public streets, non-residential driveways, roadways with truck traffic, with maximum voltages of 600 volts, a minimum clearance of 18' is required.
    okiedokie Thanks this.
  6. vickeybear
    4
    Thank you so much for such fast responses! There were no warning signs to truck traffic.
  7. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    I'm betting that this was a recently installed "service drop," from a power line on one side of the road, to a power customer on the other side. Or it could have even been a "private drop," from a customer on one side of the road to a pump house, (or something similar,) on the other side. May not have even been installed by the power company, but by the property owner, (or his electrician.) Usually, power utility companies are much more responsible than putting in low lines over roads.
    Are you sure it was power, or could it have been cable TV? Those outfits are notorious for putting in lines that are not up to code. I took one out one time in the driveway of a county building, with a 12'6" trailer. Had absolutely no repercussions from it.
    OTOH, I was delivering to a school one time, and was following directions given by the school custodian, when I noticed a power line that I certainly would have taken out, running from a main building to a portable class room. This was not on a street, but on a driveway on school property. Custodian was less than thrilled at having me tell him I'd drop the freight right there, and it was up to him to take it where he wanted it. . .:biggrin_25522:
  8. snowwy
    20,527
    13,265
    Jul 6, 2009
    regardless of what the laws are. it's the drivers responsibility to be aware of his surroundings.
    that means. "LOOKING UP"
    i just delivered a load this past monday, on a very narrow hillside road barely wide enough for cars. the kind with trees and powerlines decorating the road. the guy took me on a test drive. everything looked good from a utility standpoint. but when i drove up. come right up on a 12 foot tree limb. i didin't notice on the test drive. the guy had to chop it down.
    Big Don Thanks this.
  9. ACH1130
    ACH1130 Road Train Member
    2,695
    824
    Jan 23, 2011
    Land of far far away,
    In NY has to be 14 feet or higher. That's all roadways. The only time my job will write you up is if you had no reason to be on that road, like residential
  10. xsetra
    xsetra Road Train Member
    5,098
    6,952
    Aug 21, 2011
    Contact your insurance agent. Not to file a claim but just to alert them of a possible claim. I have done this in the past with down lines. Usually nothing comes of these down lines, the utility companies have always repaired with no chargebacks.
    I hauled house for many years a lot of residential areas have low wires. Never had to file a claim.
    Just a little CYA. Also it keeps third parties from trying to extract a few dollars from you with claims of property damage.
  11. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    Sounds good in theory there snowwy...but not completely true. If the road has no embargo, or restriction on it....and there is no signage of any kind or warning of a low clearance of any kind---one should feel safe enough to travel at posted speeds without extra worry. And driving at posted speeds, would most likely not give the most seasoned of drivers enough time to notice an overhead wire in time to not hit it (because you are not looking for it).
    Can't keep us "guessing" because we are supposed to be professionals. We as motorists (regardless of weight and number of tires) have a certain expectation of the Department of Transportation...and that is to inform us of which roads we can safely travel, and the easiest way to do that is through signage.
    I just hope the OP's company doesn't try to consider this incident "preventable" because snowwy feels everyone should be aware of their surroundings regardless of circumstance.
