overhead procedure on d13?
Discussion in 'Volvo Forum' started by letsgofast, Sep 19, 2016.
  1. letsgofast
    letsgofast Bobtail Member
    25
    8
    May 9, 2013
    Does anyone know the procedure/specs for running an overhead on a d13h model?
  3. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    i can give the procedure but you need shims to adjust the exhaust brake and a shim kit from volvo is around 1100
  4. letsgofast
    25
    8
    May 9, 2013
    well I just replaced injector cups how necessary is it to run an overhead? I'd feel better if I about it if i did! Any info would be great!
    Dave_in_AZ Thanks this.
  5. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Adjust injectors touch plus 240 degrees and just check the valves if you have a little bit play on exhaust not a big deal make sure you set up intake at .008
    sully91 and letsgofast Thank this.
  6. Mauricio.5283
    Mauricio.5283 Bobtail Member
    45
    27
    Oct 20, 2017
