overheating engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by davidg387, Jul 23, 2014.
  1. davidg387
    davidg387 Bobtail Member
    4
    My truck is overheating when I climb hills and my fan won't kick on .how do I fix this problem?
  3. 201
    201 Road Train Member
    12,622
    25,909
    Apr 16, 2014
    high plains colorado
    Hi davidg, sounds like the sending unit for the fan is bad. Depending on what kind of motor you have, my Cummins was on the thermostat housing. If you find it, with the engine running, run a jumper wire across the terminals and see if the fan goes on. Be careful.
  4. pupeperson
    pupeperson Light Load Member
    216
    203
    Jun 9, 2013
    Could be the radiator is just plugged with bugs and dirt. How many miles / years since it was removed from the truck and properly cleaned? What kind of environment are you working in? If it's a lot of dirt like logging or something like that, a radiator can get plugged up pretty quick. It could actually be lots of things: A thermostat sticking, a water pump w/ the impeller slipping on the shaft (seen that more than once) or one that's just worn out, fan clutch failure, slipping or broken fan belt ---lots of possibilities including sensor or ecm problem.
  5. davidg387
    4
    Running back and forth mi-tx.bought truck in 2012 it's a 2007 peterbilt 387 has 890000 miles on it was also told could be fan clutch. How much does something like that cost?
  6. 201
    12,622
    25,909
    Apr 16, 2014
    I don't know, fan clutches aren't that expensive, but it's kind of a big job to replace it. In my older BC Cummins, the clutch was air operated, meaning, an electric sensor went to a solenoid that triggered an air valve that engaged the fan. So I'd make sure all that other stuff is working before you go with the clutch. Unless it's a vicious drive, like on a A/C equipped car, where oil in the fan hub gets hot from air coming through the radiator, and engages the fan, but it's probably air driven.
  7. lfod14
    lfod14 Road Train Member
    1,178
    689
    Jan 9, 2014
    If its running otherwise, just not enough for the hills then its probably the clutch. Not a big deal but as others have stated theirs a few different types which can change how difficult / time consuming the swap out is.
  8. turbo64
    turbo64 Light Load Member
    58
    11
    Jul 25, 2014
    If its a horton fan and 99 out of 100 are you put a nine sixteenths bolt in the fan find the other hole and it will run all the time until you get it fixed
