Oversize and wide loads
Discussion in 'Questions To Truckers From The General Public' started by doglover44, Jul 20, 2011.
  1. doglover44
    doglover44 Light Load Member
    191
    28
    Apr 30, 2008
    What is the difference between them ?
  3. soloflyr
    soloflyr Medium Load Member
    563
    1,687
    Nov 6, 2009
    Houston, Texas
    Oversize covers everything from over height, over width, over weight, over length.
    Wide Load is just another name for the over width loads.
  4. GrillN
    GrillN Bobtail Member
    45
    7
    Jul 5, 2011
    Miami,FL
    Thank God you knew the answer to that rocket science.. lol:biggrin_25523:
  5. rodknocker
    rodknocker Road Train Member
    1,242
    584
    Dec 18, 2008
    Southeast
    We used to be required to use wide load signs in Ga. Nowdays, I believe its just oversized signs is all that can be used, at least that was the way it was 9 years ago when I used to do that sorta thing. It really didn't matter if it was too wide, too high or heavy... Oversized was what we used. I think it was the law to use only oversized. At least that's what I was told and never heard anything different from the 100's of scales I've crossed. I never was much into reading those dot handbooks
  6. okiedokie
    okiedokie Road Train Member
    11,747
    85,376
    Jun 13, 2011
    PNWET
    There is over sized and there are long load banners in this neck of the woods
  7. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    OVERSIZE is the most widely used banner now. Most states require it and will stop you if anything else is displayed. Lights, flags, escorts vary from state to state by height, weight, length. Your permits will normally spell out what is required and info is also in books at truck stops. If your not sure call and inquire or have your dispatch do so. If your stuff is in order OD is the way to go. Better pay and not boring.
  8. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    oversize is a truck that requires a special permit due to its size exceeding legal limits be it height length width or weight
    wide load is what you call the 500 lb supertrucker making his 4th trip back to the food table at the TA buffett
  9. okiedokie
    11,747
    85,376
    Jun 13, 2011
    PNWET
    don't forget to cover your banners when your mty,unless your still OS. Triples,t&t w/ pole trailers and stringers are bannered long load.
  10. Big Duker
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    You are sure right about banners. Unloaded in terrible weather in CO. Tornado warning right overhead. Loaded up all chains, binders, etc. Got to Raton on 25 and NM scale gave me good talking to for forgetting banner on front of tractor. Hell I was getting hit w/hail and gale force winds. Swallowed hard and told him I was sorry instead of what I would have preferred to say.:biggrin_25523:
  11. doglover44
    191
    28
    Apr 30, 2008
    The reason I asked is because I see moible homes labed as both on the road.
