Oversize / overload HELP
Discussion in 'Heavy Haul Trucking Forum' started by Marlop, Sep 17, 2019.
  1. Marlop
    Marlop Bobtail Member
    We are in need of OVERSIZE permits...we have been researching and we got a permit through Webcat, we got an "Virginia Overload Permit" 5%, and it was $20.
    we have many questions, is this for overweight or oversized load? in the sticker it only says "overload". so, we are pretty confused now.
    TIA
  3. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    An oversized permit will specify what dimensions you are allowed. You have a permit to go overweight a little bit.
  4. CousinVinny
    CousinVinny Medium Load Member
    615
    1,772
    Jan 26, 2015
    New Jersey
    My permit dept. tells me that the $20 VA permit covers both OS/OW.
    Edit: well not according to the guy above me so maybe my permit dept. is asleep at the wheel right now.
    Oxbow Thanks this.
  5. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    That's the info I got from the VA website but I've never seen the permit or what it actually states so I could be wrong.
    They also say it's 250 bucks.
    But if it covers oversize conditions it should state the sizes it covers.
    Oxbow Thanks this.
  6. nikmirbre
    nikmirbre Road Train Member
    5,534
    10,150
    Jul 27, 2011
    High Point NC
    The Virginia annual covers up to
    You just gotta read the permit and whatever it’s limits are vs what you asked for from webcat
    brianv31, beastr123 and Oxbow Thank this.
  7. brianv31
    brianv31 Light Load Member
    201
    514
    Mar 5, 2010
    IL I-74 mile 149
    X2 Some states are a little tricky to read, but if you're holding a VA permit, they are very straightforward. The second box from the top after your company name and truck ID tells you what the permitted dims, gross weight, axle weights and spacings are and your requirements in order to move (pole, signs, flags, etc)
    nikmirbre Thanks this.
  8. Ridlingdj
    Ridlingdj Medium Load Member
    414
    562
    Dec 12, 2018
    Having used to live in va the permit that you have is for trucks being loaded in a field and allowing you to add a extra 5% over legal weight incase you put to much on the truck and depending upon the oversized load you need to haul you might be able to get a annual permit if not you will need a trip permit
