OVERSIZE/OVERWEIGHT??The maximum weight load I can put on a 40 ton RGN with the two axle truck
Discussion in 'Experienced Truckers' Advice' started by USA/CAN Zip, Apr 19, 2017.
Page 1 of 3
Well there's a question that won't get answered without more information.
MM71, Razorwyr and OLDSKOOLERnWV Thank this. -
What does the truck and trailer light weight at?
MM71 Thanks this. -
What states are you running? What are the axles on your tractor rated for ....
All I hear are crickets...............
passingthru69 Thanks this. -
Divisible load?
Planned route? Interstate or off interstate?
Divisible load? Take your empty weight and subtract it from 80000. Nondivisible on the interstate with 5 axles total, usually 94000 GVW. Tires and axle ratings up to snuff, usually it's 20000 per axle. But beware...loading a 5 axle rig more than 93000 takes precision. If you go over axle, you have to call a crane and get it fixed at the weigh station.W900AOwner, FerrissWheel, DDlighttruck and 2 others Thank this. -
Is the 40ton trailer a two or three axle? Safe planning is 12k steer(unless you have a larger rating) and 20k per axle. That is the lowest state rating. Some will allow up to 25k per.
W900AOwner Thanks this. -
Your tractor will have a plate on the door jam or just inside.
On that plate is the GWVR for that tractor. NOT the GWVR for the combination in total. Not usually.
If you got a two axle tractor, Im going to presume you can load to 9 ton on the drives and 6 ton on the front. Im also presuming day cab. That will make it maybe at most 10,000 pounds on a really small day cab. Call it 5 ton. 6 is better. ah what the heck 7 total tare empty tons with fuel.
15 ton take 7 away makes a payload of around 8 tons possible.
Now your trailer, whatever it is has a gross weight vehicle rating on IT's stamp plate near the glad hands. That is the weight you cannot exceed.
Until we find out what sort of trailer we are doing I cannot proceed further. -
My question is, if you can't figure this out. Are you ready to get into the lowboy world?
sawmill, ChicagoJohn, wore out and 3 others Thank this. -
I was trying to start him out slow
, probably all confused now lol.
sawmill, DDlighttruck, x1Heavy and 1 other person Thank this.
Page 1 of 3
