Oversize routing
Discussion in 'Flatbed Trucking Forum' started by csw1818, Feb 13, 2016.
  1. csw1818
    csw1818 Medium Load Member
    377
    139
    Feb 6, 2014
    pinehurst, nc
    I recently got me a oversize load it's a cat canopy 112 inches wide 128 inches long and 28 inches high. So I had to get permits I work at prime I have all my flags probably too many actually. 2 on front of truck 2 on front of trailer 2 on rear of trailer and 4 on each corner of load sticking outside the rub rail. Now if I read the permit south Dakota says I have to have one or more blinking lights on each extremity of the load, is this really necessary for a 9 foot 4 inch wide load? I'm also going through north Dakota, montana, idaho, and into tacoma Washington port. I was glad to take the load at first but this seems like a hassle being I would have to figure out how the heck to power those blinking lights they sell in the big chain truck stops which usually require a 12 volt cigarette lighter... the load is on my trailer how in the heck am I supposed to power those things?
    Also why in Sam hades did iowa pull me off a perfectly fine interstate with 11ft wide lanes to put me on narrow 2 lane roads? I can only assume that SD and ND is the same way running us 18 to i29 Nb then us 12 to i94 in Montana personally this doesn't make sense to me.
  3. haulhand
    haulhand Road Train Member
    I'd imagine that the lighting requirements in SD are for night travel which is allowed up to 10 wide. Read your permit a little more close and I imagine you'll find that. If running I. The daylight I wouldn't worry about it. You should get a set of battery operated magnet mount FoxFires tho they work awesome for lighting up corners. The routing is something you just get used to try being 15 wide and routed off the interstate onto those same narrow ### roads it can get intense at times.
  4. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    If you are in Iowa why are you running thru South and North Dakota? Washington is west. I would have taken. 90west to 212 in South Dakoto thru Wyoming back to 90 in Montana.
    I would have bought an annual permit for both Iowa and South Dakota, they are cheap enough and you can run any route you want, if you check with the state first for construction.
    You can wire your amber flashing light into your running lights in rear of trailer. I think you also need one flashing in the front of your truck.
    Washington requires you can see to the rear of your load in your mirrors. You should be ok with that little load.
    Don't forget your Oversize Load signs front and rear.
    There is no rhyme or reason at times for routes the states give. You might be getting routed around a narrow restricted lane for construction that hasn't even started yet.
    Good Luck.
  5. xsetra
    5,094
    6,941
    Aug 21, 2011
    POE Washington Scale will be open 99.99% sure. Double check and make sure everything is good.
    Flags lights and signs, and do you have the required number of snow chains.
  6. TripleSix
    128,048
    Haulhand called it. The flashing lights on the extremities is for a night run.
    12 goes through the Badlands. Not a bad road. Id wager that wvery one of us that roam both the States and Canada have been through that area.
    Theres a StaMart truck stop in Mitchell SD. You can grab some OSOW supplies there (those FireFox lights that @haulhand mentioned). The weather in those parts can be extreme and a night run can help get you out of a bind. StaMarts normally have better food too. A real family restaurant, so please bathe.
    In those areas, where the StaMarts and Town Pumps are, its a different scene. You have your locals whocome in there because the food is good, your cattle haulers, grain wagons, oilfield drivers, farmers...everyone goes there. And there's usually a wateringhole. Life is too rugged in those areas to be handholding like the big chain truckstops try to do for the thousands of mega carrier morons.
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    You only need flags on the outer extremity corners of the load. Unless Iowa wants that many flags.
    ((( I saw one guy flag his truck, front and rear corners of trailer. Rear of load. ( 60 ft. rebar ) ))) I don't know who told him he needed that many flags.
    Used to be trucks ran flags on the front bumpers but don't see that much anymore. On the west coast, anyways.
    You need amber lights on the front corners, red on the rear corners. For night driving.
    Some states might also want amber lights on the truck. Usually on top. Or sides.
    Some states won't make you need lights at all up to 10 ft wide. ( CA is one state )
    I don't know why you're going through north dakota. You're going to be 90 through SD, using 34/79 up to 90 in MT. With a short corner through wyoming. ( Depending on your pickup city in iowa )
    If you have a laptop. Google is your friend. Check load requirements and lights as you get to each state. Very seldom do i get any of that information with my permits. Mostly, all i get is the permit itself. And any road closures listed on the permit. I keep the websights open on the laptop. Just in case i need to print out the extra information sometimes required. As i roll through the states.
  8. snowwy
    20,527
    13,262
    Jul 6, 2009
    If there's a loves on your route.
    Loves sells the little round beacons. On sale right now for $12.99. Free if you got points,. Batteries will last 60 hours on flash mode. I never use solid mode. They'll all have the red lights. Some will have ambers also. And batteries ARE included.
    mitmaks Thanks this.
  9. snowwy
    20,527
    13,262
    Jul 6, 2009
    Don't forget to read for speed and lane restrictions also.
    Some states keep you at 55. Some states make you use hazards if your climbing a hill and can't maintain faster then 20 mph under the speed limit. And some states confine you to right lane only.
  10. csw1818
    377
    139
    Feb 6, 2014
    pinehurst, nc
    To those that asked I have no idea who planned the route but it wasnt me, I have to obey curfew and it permits say stay within the posted speed, I have banners on front andv rear and I started in Illinois they made me run i74wb to i474wb to i74wb to i80 into iowa then i35 nb to Iowa 3 wb to us59sb to Iowa 3 wb to us 59nb to us 18 to Sioux Falls sd then i29nb to us 12 across sd and ND ... and I still need my Montana and idaho permits faxed to me, but hopfully I run i90/94 there. I wanted to eventually run oversize and heavy guess I have to start somewhere.
  11. TripleSix
    128,048
    Probably someone in you company GPSed and requested the shortest route. 74 to 474 to 74 to 80 has to be the most common OSOW route in the country.
    Kudos for reading the permits and doing your homework and trip planning. I don't know how you plan your fuel stop, but I fuel at the beginning of the day. Not after my day has started. You have too little time for that in the winter.
    rank Thanks this.
