Oversized fema loads and hos
Discussion in 'Heavy Haul Trucking Forum' started by Josielynn1989, Nov 2, 2017.
  1. Josielynn1989
    Josielynn1989 Bobtail Member
    5
    so we are going to be hauling modular homes for hurricane relief to Texas from pa the western service center emergency declaration just got extended does anyone know if we will qualify for the hos exemption in all the states I know we need permits ect except in Texas and a few states have their own declarations but does the 49 cfr 390 through 399 that doesn’t have to specifically do with oversized still apply
  3. xsetra
    xsetra Road Train Member
    5,096
    6,946
    Aug 21, 2011
    Oversize driver is not required to take 30 minute break in 8 hour drive on duty.
    This HOS exemption is permanent. Driver should carry printout of exemption to be safe.
  4. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Yes. If there is an active emergency declaration for which you qualify then you are exempt in the state of origin, the state of delivery, and all states through which you must travel. As you said, you are not exempted by the federal exemption from state oversize/weight laws and must still get permits unless the state gives an exemption.
    Nothing in that exemption specifies that oversize loads do not qualify, and since the fmcsa specifically mentions that the exemption doesn't exempt you from permitting requirements you can assume that it does cover oversize loads.
    Keep in mind that while HOS may not apply any curfews and night travel restrictions will still apply, unless the state has an emergency exemption for that but not for the permit itself. Since I don't make habit of travelling those states I'm not familiar with curfews or time of day restrictions over there.
  5. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    There is more to it.
    1) There is no "Should" carry a copy of the exemption. You MUST carry a copy of the exemption document and present it to law enforcement upon request.
    2) Only drivers moving in interstate commerce can use the exemption, not intrastate.
    3) All motor carriers using the exemption must have a "Satisfactory" or be "Unrated" by the FMCSA. Carriers ratings of "Conditional" or "Unsatisfactory" can not use the exemption.
    4) All motor carriers using the exemption must have a SMS score under the FMCSA intervention threshold.
  6. ChaoSS
    3,338
    6,755
    Sep 20, 2014
    Didn't that particular exemption expire this last June? Or was there an extension that I didn't see?
  7. Jumbo
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    The following was supposed to be in my previous post. Thank you for pointing out the omission. I can not edit it into my original post now.
    5) The exemption is good for two years, through June 18, 2017
  8. Josielynn1989
    5
    It was extended to dec 22nd
  9. Josielynn1989
    5
    Not the exemption I’m talking about but got my answer talked to FMCSA today
  10. Josielynn1989
    5
    You are completely correct verified with FMCSA today thank you for your help
  11. ChaoSS
    3,338
    6,755
    Sep 20, 2014
    That's what I thought. I keep seeing people talking about that exemption for oversize and I can't find anything extending it or making it permanent.
