Overweight limits in California
Discussion in 'Trucking Industry Regulations' started by skim, Apr 8, 2011.
  1. skim
    skim Bobtail Member
    39
    6
    Nov 30, 2010
    Los Angeles, CA
    Hi...what are the overweight limits in California? I am over approximately 200 lbs in the rears and have talked to some other California drivers and they said that the scales will allow up to 300 lbs, however I believe that to be in the drive axle because of fuel. Will I be able to pass the scales being over by 200 lbs in the rear axle without getting a violation? Thanks any input appreciated.
  3. Meltom
    Meltom Road Train Member
    5,423
    3,019
    Jan 24, 2011
    what exactly are your weights? And I'm sure this is a dumb question, don't you have a dispatcher you should contact?
  4. ac120
    ac120 Road Train Member
    1,072
    550
    Aug 27, 2010
    Your best bet is to call the scale nearest you and ask.
    http://www.chp.ca.gov/depts_divs_offs/inspection.html
    If there is no tolerance for over-axle weights (that 300 lb. stuff because of fuel sounds like a fairy tale--why would they let you be 300 lbs. over on drives but not on trailer tandems?), you already know who is going to pay for it. They can make you stay at a scale and legal your load. Cover your own ***. Call.
  5. Allow Me.
    10,643
    12,114
    May 28, 2009
    Rancho Mirage, Ca.
    I've always heard 2-300 lbs leeway. Never officially though.
  6. ac120
    1,072
    550
    Aug 27, 2010
    Can't recall ever hearing that; maybe I heard it and forgot :biggrin_25523:. I was going to call the nearest scale and ask, but got busy. I couldn't find anything about it on the Web.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    You are supposed to be allowed 400lbs over if you have an APU, but that won't help on your trailer!
  8. scottchris71
    scottchris71 Light Load Member
    165
    49
    Nov 18, 2010
    iowa
    That 400 pounds for a apu..only applies if you are over gross.....Unless your apu is hanging on your trl..wont help on this issue. I would be more worried about making bridge ..depending on the scale..you will get a ticket
  9. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    Can't you just move your tandems 1 pin? That would take care of the weight.
  10. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    Has California even passed that yet? IIRC, as late as last year they had not accepted the recommendation.
