hello guys
I am little overweight on my drive axle 34340lbs.
On other axles i am ok . I have freight through Mississippi Georgia and Florida. Am i ok ? I can’t slide my fifth wheel. Thanks
Overweight on my drive axle 34340lbs, can I slide my 5th wheel?
Discussion in 'Questions From New Drivers' started by Dorde89, Jan 12, 2019.
Page 1 of 5
You’ll burn some fuel off before Florida for sure. Can’t say whether the others will let you through. But, I can help you out a bit more if I knew your starting and ending points
Getting around MS is easy. Depending on the route you’re headed, GA is too
Most will let you slide at less than 5% anyway. -
I am now on i22 driving through Atlanta and finishing at orlando . Tnx so much
You can’t slide the fifth wheel as it is bolted in place?
Or you can release it, but you’re not able to get it to move? -
The pins release pins inside but i cant move fifth wheel
uncleal13 Thanks this. -
You’re not that much over.
Alabama, no scales. Georgia, may be closed coming into Atlanta. Even if they’re open, you’ll have burned off enough fuel to get by. Even if they are open, my last take on overweight tickets in Georgia was 10 cents a pound.
I don’t know what your fuel situation is right now. So just be mindful of that. Because you still have Florida. But, you can run state routes. Those close frequentlyDorde89 Thanks this. -
In a nutshell. You’re at 1%. It’s going to take a real ####### to write you a ticket.
Personally I find it easier to just drop the trailer. Pull ahead a few feet. Then use a pry bar to put the fifth exactly where I want it. If the air cylinder is too weak to retract the pins, you can help pry out the pins at this point, the air will at least hold them out for you.Nothereoften, Metallica88 and Dorde89 Thank this. -
Thank you all for this helpful advises . I really appreciate it . I wish you all the best in the New Year
Page 1 of 5
