overweight ticket on axel had to break seal to redistribute load!!
Discussion in 'Trucker Legal Advice' started by davidx109, Aug 10, 2013.
  1. davidx109
    davidx109 Bobtail Member
    my load was a no touch, no look, [​IMG]dont get out of truck, load, as ususal. I was loaded in Iowa and went thru plenty of weigh stations.
    somehow i am 1100 over weight in ca. approx 50 miles from unload destination. got a ticket and had to break the seal to redistribute
    the cargo. I dont feel that i am responsible for the ticket since i cant even see the load . its loaded doors sealed and i only know what paperwork says.
    I think i should fight this ticket.. as not my responsilbility ..... i am very curious about the accuraccy of the scales ,
    that we all pass thru daily if i was overweight why didnt it show up at any other scales between Iowa and CA. So iam wondering if i can win if i fight that ticket..
    :biggrin_25511:
  3. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    That's interesting. Were you over gross by 1100?? Axle?? I would weigh it before you unload at a certified scale if possible.That way you have something to prove the CA scale inaccuracies (which I doubt.) it really doesn't matter what the circumstances are. If the CA scale is correct it's your ticket. You can argue with the company but you accepted the load as is and chose to run with it. It's your ticket.
  4. fuzzeymateo
    771
    783
    May 20, 2013
    AZ
    Sorry just read the axle part. Maybe it shifted during transit? If so still your ticket.
  5. andre
    andre Medium Load Member
    341
    172
    Feb 10, 2008
    Jacksonville, FL
    There are a number of reasons why you could pass by some scales and not others. I always run by the scales on I95 to the scale on US1 for this reason. Both are always open during weekdays. One is run by three good old guys, and one is run by people desperately trying to earn their chops.
    Do you have a cat scale receipt that has your axle weights? You are going to have to have proof the weights were correct. Do you have a cat scale receipt for your axle weights after you got the ticket? You are going to have to have something if you are going to take it further. Contacting a lawyer is always a good first step if you do want to take this to the next level.
  6. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    you know there isn't a cat scale receipt or the thread wouldn't be started
    or the driver changed tandem position for Ca bridge law
    todays society no one responsible for anything
    truckon, Boka and Hardlyevr Thank this.
  7. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    You should have scaled before hitting the road. It's your ticket and in commifornia you have a 2% chance of beating it. They want their money.
  8. coastie
    coastie Road Train Member
    I dont feel that i am responsible for the ticket since i cant even see the load So you can not see the product, sealed load so? what the problem Scale it before crossing a weight station. Simple
    as not my responsilbility Wrong it is yours you are responsible no matter what, if you pull it You are. Always scale out the load over 30K and if in doubt.
    Breaking the seal not that big of an issue. Done it before. I loaded in Dallas Tx going to San Jose CA. Scaled out in Fort Worth and shifted my axle to adjust. Least I thought. SO I did not rescale. Made it to AZ and got a ticket. Ok I made a mistake. Made it through NM scales but not AZ. I called dispatch They Notified the receiver and said Break the seal and shift load. I was able how ever to go to a truck stop did not have to do it there at the weight station so I was able to rescale it, which I did at 2 different TS then I used a strap to a pallet and draged it to the door and then another. Got the weight legal and went on my way.
  9. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Once you sign the BOL at the shipper you are responsible for the load. Any time I have a load over 35,000 I will always get a CAT certified scale to make sure all my axles are good. I've been overweight on one set of tandems or the other on loads as low as 36,000. Be sure you scale the load with the trailer tandems set legally to the minimum distance for the states you plan to go through.
    The bottom line is that it doesn't matter if you can see the load or not. It is your load and your responsibility the moment you sign for it. Scale the load as close and as soon as possible after picking up the load. If you have a problem then immediately go back to the shipper and have them rework the load. That is really fundamental for trucking.
    If for any reason you get tagged at a weigh scale you will then have a certified CAT scale showing that you are legal. If it is close and you have room to move the trailer tandems often the scale house folks will allow you to move the tandems and rescale without getting a ticket if you have weights on a CAT scale showing you were legal on that scale. If you don't have a certified scale ticket to show them, and if you gave them an attitude that "it wasn't my responsibility", then I can certainly understand why they issued you a citation, perhaps to help reinforce the concept that it IS your responsibility.
  10. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    Pay the ticket, promply.
    Retain the proof of payment, for a very long time, years......
    'olhand Thanks this.
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    even though you can't see the load doesn't mean squat. im sure the scale couldn't see your load when they told you you were overweight. sorry but its your responsibility to make sure that your axle weights are legal
