Owner op going to tank yanking ...
Discussion in 'Ask An Owner Operator' started by KyleWhitneyTrucking, Mar 18, 2020.
  1. KyleWhitneyTrucking
    KyleWhitneyTrucking Bobtail Member
    14
    Feb 11, 2020
    So looking to go into chemical hauling with tanker . I have a few questions .
    1. What is a good brand trailer and what specs should I be looking for ?
    2. what’s type of insurances most I Cary . Meaning ( cargo ... liability ... ect )
    3. what are some good places to get loads via load boards or companies that broker to owner operators?
    4. just some positive insight on pulling tanker / advice for a newbie getting into tanker hauling ...
    Thanks !!
  3. kemosabi49
    10,011
    41,497
    Jan 13, 2013
    SW Arkansas
    Most O/Os lease onto a company in the chemical tank world. Not to say it cant be done. But trailer needed for one load may not work for the next. Like one needs and belly dump and the next a rear unload. Although some extra piping can take care of that. Or nest load can't use a trailer that had the product you last hauled in it. Not to mention the hours used always waiting at the tank wash.
  4. Cat sdp
    Cat sdp . .
    19,884
    64,259
    Apr 8, 2012
    Orion's Belt
    You don’t want to buy a chemical tank...... unless you have a steady customer already lined up.
    Try pricing 5 million dollars in liability insurance as a new owner operator......
    As was already said Lease to someone to get started.... and go from there.
  5. Valuable Asset
    Valuable Asset Light Load Member
    98
    293
    Feb 28, 2020
    Where you are located will be the biggest factor in what you do.
  6. 18 wheels of fury
    18 wheels of fury Light Load Member
    167
    87
    Oct 31, 2015
    Houston
    you really don't need a tanker unless you have a company or dedicated customer but my company does let you bring your own tanker for a higher percentage of the load but from what I see not many have one
  7. KyleWhitneyTrucking
    14
    Feb 11, 2020
    What company is that ? And what type of tanker ?
  8. wis bang
    wis bang Road Train Member
    3,067
    3,429
    Jan 12, 2011
    Levittown, PA
    You don't want a tank...invest in the equipment for your tractor and sign on with a reputable carrier.
    anything that may make the barrel get thin and you are done unless you ant to pony up for a re-barrel which takes a while.
    25 years in chemicals, let the carrier buy the tanks, you need too many different things to really do it right.The only guys I ever saw successful with their own had a connection with the shipper, either a long term relationship or an inside connection sending it his way...
  9. 18 wheels of fury
    167
    87
    Oct 31, 2015
    Houston
    fort transfer....just a smooth bore chemical tanker
