Paccar engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Jun 9, 2010.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,746
    613
    Feb 21, 2010
    Miami
    Hi what you think about the paccar engine is this a good mpg engine or not and what is the best engine paccar ,cummins ,mercedes, detroit ,cat or a other engine typ.thanks for you answers
  3. ers3381
    ers3381 Bobtail Member
    west sunbury pa
    i been driving a 2012 pete for 2 weeks with the 485 paccar im very impressed over all fuel millegis 5.4 seems powerfull u gotta keep it up on the rpm tho if not instead of grabbing half a gear you gotta grab a full one
  4. Maxidyne
    Maxidyne Bobtail Member
    28
    Feb 20, 2010
    Portersville PA
    Boss just bought 5 of them, first day out all five had the check engine light come on! Guess we'll see where it goes from here?:biggrin_25526:Gotta say, I like my ISX..............
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I'd say this mix of PLD and electronically controlled nozzle (like ob CRD) is a good idea how to make fuel system simple but accurae for new Euro/EPA requariments... The only problem with this engine I have now is thing wiring, easy to brake wires.
  6. virgil tatro
    virgil tatro Medium Load Member
    343
    177
    Mar 26, 2010
    columbus montana
    cummins is best N-14 then ISX then detroit... dont know much about the Paccar or Internationals Maxx force engines though...
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have an ablity to know becouse there are many DAF 105 with MX running over here.
    Maxx id from Germany, it is D28 engine by MAN, it is new CRD technology... seems to me all new class 8 trucks will be with Common rail soon.
  8. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Not sure what your operation is, but if the Paccar engine can only pull out a 5.4 mpg, then I won't ever be buying one. For what I do and where I do it, if an engine can't get over 7 mpg average (not talking about -20F weather with winds of 30 mph here), then it needs to be gotten rid of. I have averaged at or above 7 mpg for at least the last 15 years with various engines, mostly Cummins and Detroits. Of course, the gearing in the one you are running could be not matched correctly to the engine for what you are doing. That could explain it.
    Just bumped into another O/O at my carrier that just ordered a new Pete with the Paccar engine. I'll see how it works for him.
  9. Scania man
    Scania man Road Train Member
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    We have those engines in dafs over here, those engines won't make half a million miles nevermind one million, I'm speaking from experience, I owned two of them, bought two new ones in 2003, one made 230,000 kms and the second 540,000 kms, that's kilometres not miles ! I know plenty of people here with the same experience, if they don't blow up before 600,000 kms they will be worn out, even newer engines are having the same problems, stay far away from them, absolute crap,
  10. DAFMAN
    DAFMAN Bobtail Member
    8
    Sep 16, 2011
    bristol
    2003 engine is xe 12.6 litre daf engine which is strong apart of rear cylinder head cracking.
    Mx is 12.9 litre from 2006 on and not as good as older xe
  11. Scania man
    2,199
    483
    Jul 1, 2011
    Saskatchewan
    Even worse? Mine the rings and pistons needed replacing , in fact a full rebuild, first 230.000 kms second 540,000kms, I've heard Alot about heads cracking too, valves dropping, bad engine, pity because it's a nice truck to drive
