Paccar ESA
Discussion in 'Trucks [ Eighteen Wheelers ]' started by kellysaville, Jul 19, 2012.
  1. kellysaville
    kellysaville Bobtail Member
    27
    5
    Jan 11, 2012
    Denver Colo.
    Paccar Electronic Service Analysis or ESA, Does anyone know anything about it?
  3. kellysaville
    27
    5
    Jan 11, 2012
    Denver Colo.
    Where do u get this software?
  4. pichu
    pichu Light Load Member
    103
    19
    Jan 18, 2009
    mexifornia
    i have this software is similar to Vcads pro (volvo) you can see all engine, trasmision, cab, diffrennctial ,abs all complete truck kenwort,and pet if you need more info .PM please
    Rolling18 Thanks this.
  5. cowcatcher
    cowcatcher Light Load Member
    Esa is a software program we use on the multiplex wiring in the newer trucks.
  6. maropafadzodz
    maropafadzodz Bobtail Member
    I m a heavy equipment mechanic and would be grateful if you can assist me getting ESA & Vcads. I work on peterbilts , freightliners & volvos. every day and having ESA & VCADS on my laptop would definitely make my work a lot easier &bearable. Thanks a lot
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ESA and DAF Davie are Paccar diagnostic system
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Paccar sells it as a package with dealer sponsorship. It's about $800.00, with a Nexiq USB link, the only connection device it supports currently. ESA is downloaded through the paccar portal, but your dealer will need to get you access and activate the license.
    It is used mostly to diagnose the multi-plexed systems, but you can also update firmware, change peramters, etc. with it.
    Ashphaltwolf Thanks this.
  9. Jaclan
    Jaclan Bobtail Member
    Jul 27, 2014
    ** DELETED **
    Oldironfan Thanks this.
  10. jaywindsor
    jaywindsor Bobtail Member
    Jul 28, 2014
    ** Get the code from the dealer **
  11. servicemanager
    servicemanager Bobtail Member
    6
    Sep 17, 2014
    Let me know if I can be of help at all.
